Page 1 of 3 123 LastLast
Results 1 to 10 of 23
Thread: Relocating trailer plug
    Not the most exciting post but just thought I would throw this out there for people to do as It works a treat!
    I was sick of bending the plug back to shape and spending time scrapping out mud from the socket after the trips.
    Simple job....Take the plug off (remember to disconnect power to the plug too). Drill a hole in the rear step, relocate the wires and screw it on the rear step plate....Job done...Out of the way from bumps and mud.
  2. The Following User Says Thank You to AB For This Useful Post:
    BigRAWesty (24th May 2013)
    Banned Bigrig's Avatar
    Oct 2010
    South of Brissy, QLD
    Seeing as I did it about 8 months ago, it's officially my idea!! lmao
    Good tip mate ...
    Quote Originally Posted by Bigrig View Post
    Good tip mate ...
    Arr mate, you can take this one..lol...I'm surprised that plug stayed there as long as it did. I spent about an hour at Loveday scrapping all the crap out as well before hooking the camper up!!!
    Oct 2010
    I'm amazed heaps of them aren't ripped off more often ...
    And nahhh .. you can have this one!!! lol
    Hardcore 04OFF's Avatar
    Brisbane,QLD
    12 Post(s)
    I had the same issue AB, i installed one of these.....
    http://www.accessoriesonline.com.au/...cat=616&page=1
    Mine has a round 7 pin end, the "flat" cable is designed to get shut in a boot/door rubber without damage, i have mine connected and sitting behind the inside flap you remove to change tail light bulbs, if you need to tow, you just pull it out and connect to trailer, then shut the back door on it as normal.
  7. The Following User Says Thank You to 04OFF For This Useful Post:
    AB (30th April 2012)
    Commodores have them and they are the best....Bummer, never even thought of that....lol...Feeling down now!!!
  9. #7
    Expert ripper's Avatar
    Leeton NSW
    Good tip mate ...
    Our Trol had one like that when we bought it
    Since then I added a flat one and piggybacked it off the round one, then screwed it onto the bottom of the step.
    A word of warning to anyone drilling through the step like Andy did. Make sure there's not a mounting bracket behind where you drill the hole. Whoever did ours hardly left enough room to get the wires past the bracket, and if you get it wrong you'll end up with an ugly hole that the socket can't cover.
    1989 GQ LWB Wagon, TB42 Petrol/LPG Auto. Bought Dec 2010
  10. The Following User Says Thank You to ripper For This Useful Post:
  11. #8
    Yep I forgot to mention that. I did check out what was going on behind the step. If you drill directly on the corner bend of the step then it misses the bracket and bar, etc and is an easy direction for the cable to run through as well.
  12. #9
    Leeton NSW
    Minor hijack.
    A flat plug fits really well under the step.
  13. #10
    Aug 2010
    Lower Blue Mountains
    17 Post(s)
    Because I have a 2inch body lift I located the flat plug between the top of the rear bar and the body itself
