Results 1 to 5 of 5
Thread: Coil spacers.
    Advanced GQ snail's Avatar
    South Brisbane
    Coil spacers.
    Hay team.
    Am thinking of getting either 30 or 50mm coil spacers. Currently have stock suspension on the GQ. Looking at 2" lift in future.
    What are peoples thoughts on spacers, GOOD or BAD
    Saving Yotas Since Creation
    Expert 4by's Avatar
    Northern Vic
    I've had them in my 4wd and so do my mates. Rules are only for offroad use but I bet alot off people use them on road. You will need to change your shocks for longer one. They can also be used to level sagged suspension. I bought a gu with 50mm in the front and rear with longer shocks. Previous owner did a few offroad trips etc and no problems. I pulled out the rears to put in thicker springs so I'll be offloading the rear set. You could go 50mm in rear and 30mm in front. Or you could buy a second hand set of coils with shocks for not much more dollars......
    Cheers 4by
    Can I put a Holden badge on my Chevy ?
  3. The Following User Says Thank You to 4by For This Useful Post:
    GQ snail (30th April 2012)
    Feb 2011
    Shed
    45 Post(s)
    IMHO i think they give you a weak link in your suspension, Id wait until ya can do the 2" lift properly.
    North brissy
    Quote Originally Posted by growlers71gq View Post
    I tend to agree these are just a cheap fix for sagged springs if you do use them make sure you retain them somehow zip ties etc 2" lifts arent overly expensive i would just wait til you have the coin and do it this way.
    South Brisbane
    Thanks.
    Think I will wait and do it all properly, nearly have coin for lift and think will be more satisfied with bright new springs and shocks under the old girl.
