Results 1 to 3 of 3
Thread: GQ Diff Ratios Man/auto TD42??
    Nov 2011
    Townsville
    Can anyone tell me what Ratio diffs would have come in a 07/92 Built GQ LWB wagon with a TD42 and Auto trans? My parts rig is a TD42man trans '89mdl which I believe should have 4.11's. I would normally assume the auto would run taller diff gears but I dont know, I swapped the manual box into the Auto car and I could have sworn it was reving less with the Auto than it does now with the manual?? I thought it used to sit at about 2200rpm in lockup OD @100 now its 2400 in 5th @100?? am I dreaming or is the final drive ratio of the auto taller than the 5spd man??
    cheers Andrew
    should tell you on the plate hh41 usually for a td42 manual
  3. The Following User Says Thank You to 97_gq_lwb For This Useful Post:
    Killametre (29th April 2012)
    Expert johno90's Avatar
    Moranbah QLD
    The auto box has different gear ratios. can't remember exactly what they are tho.
  5. The Following User Says Thank You to johno90 For This Useful Post:
