Page 10 of 10 FirstFirst ... 8910
Results 91 to 93 of 93
Thread: ECU diagnostics
  1. #91
    Banned Bigrig's Avatar
    Oct 2010
    South of Brissy, QLD
    Quote Originally Posted by YNOT View Post
    Not quite, there are 2 ways to do it.
    1, In post #86 you said your timing (distributor timing) was advanced 4 degrees (I'm assuming that was done so it runs better on LPG). If you leave that as is then your base timing is for gas and you then ECUtalk retard it 4 degrees for petrol.
    2, Reset the timing back to standard so your base timing is for petrol then ECUtalk advance it 4 degrees for LPG. That is how I would do it.
    If you are finding that it runs OK on petrol at 4 degrees advanced then leave it there (as petrol base timing) and advance it 1 or 2 degrees at a time for LPG until it just starts to ping - turn the radio OFF for this, then retard it 2 degrees to stop it pinging. If an engine is allowed to ping for too long engine damage will occur so be careful.
    Tony
    Thanks mate - might play with that Saturday morning as I'm still not quite with you (only on the base timing etc bit - didn't think you could set it differently for either fuel source).
  2. #92
    Aug 2010
    Lower Blue Mountains
    17 Post(s)
    Digging up an old thread,
    Roofy, did you get yours and did it work?
    boggy2006, havn't seen you on here in a while, hope all is well, same Q for you if you see this thread
    Todd
  3. #93
    Patrol God Sir Roofy's Avatar
    TRAFALGAR VIC
    35 Post(s)
    Quote Originally Posted by nissangq4.2 View Post
    digging up an old thread,
    roofy, did you get yours and did it work?
    Boggy2006, havn't seen you on here in a while, hope all is well, same q for you if you see this thread
    cheers
    todd
    hi ya toddy got it never used got the 3l now so i dont really need it now
    thanks mate for your interest
  4. The Following User Says Thank You to Sir Roofy For This Useful Post:
    NissanGQ4.2 (20th April 2012)
