Page 18 of 24 FirstFirst ... 1617181920 ... LastLast
Results 171 to 180 of 235
Thread: Forced Offroad. Gq v8 daul cab.
  1. #171
    looks good mate
  2. The Following User Says Thank You to msw21 For This Useful Post:
    Forced Offroad (10th April 2012)
  3. #172
    Expert ozzyboy's Avatar
    Oct 2011
    springwood, qld
    great build so far mate. lookin forward to seeing this thing on the dirt. ( probably not as much as you looking forward to it though :P )
    ozz
  4. The Following User Says Thank You to ozzyboy For This Useful Post:
  5. #173
    great work mate
  6. The Following User Says Thank You to Alan GQpatrol For This Useful Post:
  7. #174
    Expert Forced Offroad's Avatar
    Apr 2011
    Logan/Daisy Hill
    Cheers guy's
    NOt much more done except the rear wall to the truck which a big thing, as all i need to do is a bit of grinding as i have changed my mind again
    More gear ordered
    Tigerz11 awning with the silly prices at the moment
    Rhino platform racks with a cool little mod with one http://www.rhinorack.com.au/AccSubCa...-Racks_74.aspx
    FORCED OFFROAD
    Built by NISSAN Powered by HOLDEN Perfected by ME "hulksta"
    http://www.youtube.com/watch?v=3GX2M...layer_embedded
    http://www.nissanpatrol.com.au/forum...Gq-v8-daul-cab.
  8. #175
    Apr 2011
    Logan/Daisy Hill
    Bit of detailing,
    Fired up the engine for a good hour tonight, and gave it a little service as it been sitting still for nearly 2 years. Forgot how nice it sounds.
    New battery,new hight torque starter motor,new ignition Module has been done over the past year. So I hope I can get from A to B,C,D,E,F and G I venture further. Always seem to break down in bad areas, but always been lucky to get it started.
    FORCED OFFROAD
  9. #176
    Apr 2011
    Logan/Daisy Hill
    Bit of wiring up tonight.
    Something different
    FORCED OFFROAD
  10. The Following 3 Users Say Thank You to Forced Offroad For This Useful Post:
    Clunk (21st April 2012), growler2058 (19th April 2012), NissanGQ4.2 (19th April 2012)
  11. #177
    Nov 2011
    Brisvegas Northside
    Haha like it...is that brake/ tail switched?
    Or a switched fog light?
    Nothing wrong with thinking outside the box.
    Slip the light off, pass it and wiring through the rim and easy access to the spare wheel as required.(if ever)
    Dave
    99 GU 2.8 TD
    Brisvegas, QLD
  12. The Following User Says Thank You to robbo0001 For This Useful Post:
    Forced Offroad (19th April 2012)
  13. #178
    Apr 2011
    Logan/Daisy Hill
    Its both mate tail and brake.
    The wiring will be all concealed and hidden away. This was the test run getting the loom right.
    FORCED OFFROAD
  14. #179
    Apr 2011
    Logan/Daisy Hill
    All wired up for the rear light set up.. Hopefully this will keep the DOT happy with more than enough brake/tail and indicator lights.
    passenger side is not in as I cant find the bloody screws, Also the rear flood light in hooked up to the reverse power. So when its in revers it will light up the bush.
    FORCED OFFROAD
  15. The Following User Says Thank You to Forced Offroad For This Useful Post:
  16. #180
    Apr 2011
    Logan/Daisy Hill
    Bit greedy,but have come up with a easy mounting bracket if you own a iPad . Will post build on it when I start.
    Should stop buying toys and finish the freakin truck.
    FORCED OFFROAD
  17. The Following User Says Thank You to Forced Offroad For This Useful Post:
    growler2058 (25th April 2012)
