Results 1 to 10 of 11
Thread: Crankcase Evacuation System
    Sunny Coast
    Has any one toyed with the idea of running the crank case gas back into the exhaust to save the oil clogging up the inter cooler etc ?
    Hardcore the ferret's Avatar
    Sep 2010
    on the coast W.A.
    I think back pressure would be an issue Timbo, plus blocking up the exhaust with oily soot!!
    But ya never know eh??
    Cheers, the ferret.
    Expert BearGUST's Avatar
    Apr 2011
    Mornington Peninsula
    It'd be illegal, you may as well just vent it to atmosphere if you were going to do that.
    Sep 2010
    on the coast W.A.
    For what it's worth, the SD33 's vere vented to the atmosphere and never had dirty inlet manifolds, they would drip a little oil tho.
    Cheers, the ferret..
  5. The Following User Says Thank You to the ferret For This Useful Post:
    timbo1 (5th April 2012)
    Sunny Coast
    Thx Ferret, would the one way valve in the breather stop any back pressure entering the engine? they seem to work on petrol engines http://www.jegs.com/i/Moroso/710/25900/10002/-1
    cheers
    I drop mine to atmosphere the one on the gq drops a minute amont of oil but drops it onto the slip joint of the front tailshaft. You would have to be careful as while the engine is revving and forcing gas out this will create a vacuum in your crankcase. I would just drop it to atmosphere no oil in intakes etc and is very easy to do.
  8. The Following User Says Thank You to nissannewby For This Useful Post:
    Sep 2010
    on the coast W.A.
    Quote Originally Posted by timbo1 View Post
    cheers
    I would say the exhaust pressure would overcome the non return valve and and end up with nothing going anywhere.
    It would smoke like a chimney when hot, and stink.
    A catch can is the best option I'm afraid.
    Cheers, the ferret.
  10. #8
    Patrol God Dhuck's Avatar
    Nov 2010
    Crap Weather State
    5 Post(s)
    Welcome to the forum mate.
  11. #9
    Go the Provent Catch can. Bugger the Environment! Think of the Motorcyclist going around the bend behind you on wet bitumen! He will thank you for not dumping it on the road
  12. #10
