Results 1 to 10 of 11
Thread: Multi meter reading @ 18 volts!
    Advanced Barney Rubble's Avatar
    Eltham.
    Hi there guys, i have posted this in another thread but realised now you have a dedicated place for electrical.
    My guage when i am driving reads at 18 volts, so i bought a multi meter and tested it thinking that perhaps it was a faulty reading. but NO.. it is actually reading at 17.63 volts. What could be causing this and how should i go about fixing this?
    Cheers Barney Rubble.
    Sometimes it's the destination, but usually its the journey!
    Banned Bigrig's Avatar
    Oct 2010
    South of Brissy, QLD
    Over charging isn't good boss ... can cause the battery to blow in some instances.
    More than likely a stuffed alternator, but others with more auto sparky knowledge will be able to assist no doubt ....
    Something to be ironed out quick smart though mate.
  3. The Following User Says Thank You to Bigrig For This Useful Post:
    Barney Rubble (2nd April 2012)
    Hi mate, I would be getting that battery out of the vehicle and away from anything of value until someone on here can give better advice.
    As discussed, It may be your regulator on your alternator overcharging your battery as it happened to me but it nearly exploded at only 15 volts. 17.63 is huge mate and I would very very careful. I didn't even know it could get up that high without blowing some cells at least.
  5. The Following User Says Thank You to AB For This Useful Post:
    Expert BearGUST's Avatar
    Apr 2011
    Mornington Peninsula
    Voltage regulator, get the alternator looked at straight away.
    This would be likely causing a heap of other issues in the car. Blown globes at least.
    Eltham.
    heading down to find an auto elec now... will update with findings.
    Quote Originally Posted by Barney Rubble View Post
    Unplug your alternator to the battery mate and turn everything possibly on in your car if you are driving it down there...
    Music, air vent, all your lights, chargers, etc....Try and drain that battery!!!!
    Gladstone
    Yeah, sounds the voltage regulator in the alternator. Have a look in the cells of the battery and top them right up with demineralised water before you head off anywhere to stop them boiling dry. Leave the alternator connected if you are driving but put on the a/c and crank your stereo and lights on. The battery will handle this for a short time but it does need looking at.
    Cheers, bazzad
  10. The Following User Says Thank You to bazzad For This Useful Post:
    Barney Rubble (3rd April 2012)
  11. #8
    You may also start blowing bulbs and electronics in the car if you're not careful. Had to replace every bulb on an n14 pulsar that was doing this once.
  12. #9
    Banned
    Apr 2011
    Greenbank QLD
    25 Post(s)
    Check the voltage regulator sense wire at the alternator. It is the small white wire in the two pin plug that connects to the alternator.
    It should read the same as the main power connection at the alternator (large wire wire).
    On the GQ, the small wire connects to the large wire about 6inchs away from the alternator and it's not uncommon for this connection to fail.
    Does your alternator/battery warning light in the dash work correctly. The light comes on when the ignition is turned on and then goes off when the engine is started.
    If the above are ok then the fault will be with the alternator.
  13. The Following 4 Users Say Thank You to Yendor For This Useful Post:
    Barney Rubble (3rd April 2012), BROOZA (23rd April 2012), MudRunnerTD (2nd April 2012), Robo (3rd April 2012)
  14. #10
    Eltham.
    Thanks guys... the GQ is in at the mechanics now. Auto elecs had moved.
