Results 1 to 4 of 4
Thread: winch question ??
    Advanced cookpa's Avatar
    Feb 2012
    Tuncurry
    winch question ??
    ok i just got my first winch got a deal on an almost complete winch $0 dollars just had to buy a new rope / cable and hook , my question is why is a hook used , why are we not using rated bow shackles , i know it may be a dumb question maybe has something to do with safety? but i am new to winchs thought it was a good question
    thanks
    You can use shackles if you want. Hooks are considered more versatile is all. As a point of interest, check out the rating on the hook, or the clevis pin for that matter, you'll be suprised at that as well.
  3. The Following User Says Thank You to the evil twin For This Useful Post:
    cookpa (4th April 2012)
    spring ridge
    A bow shackle can also be a bitch to undo if it is put to its limits as well unlike a hook
  5. The Following User Says Thank You to spring_ridge_guy For This Useful Post:
    334 Post(s)
    Quote Originally Posted by spring_ridge_guy View Post
    This should not actually be a problem if used correctly? No disrespect intended.
    When using a rated shackle you should do up the pin then undo a good 1/4 to 1/2 turn to avoid stress fusion and lockup of the pin after being loaded up in a recovery.
  7. The Following User Says Thank You to MudRunnerTD For This Useful Post:
    Benno7 (5th April 2012)
