Results 11 to 20 of 22
Thread: Marine Ply ok for Rear Drawers.
    Expert Russell1974's Avatar
    I have built 4 sets of drawers for mates all I used was 12mm mdf board cheap as chips to buy most places have these as cover sheets they are now 3 years old and are still as strong as the day I made them
  2. #12
    ilikedonuts_10
    Guest
    Hi I was looking at building a set of drawers for my GQ to fit in a fridge as well, what material have you used for the fridge slide? is marine ply strong enough or have you had to reinforce it with metal?
  3. #13
    ilikedonuts_10
    Guest
    Also what specifications have you built it to?
  4. #14
    Oct 2010
    selby, victoria
    yeah marine ply is a little overkill if it's going inside the car.
    just get the lower grade stuff and coat it with something to water proof it.
    another way for the draws to slide easy is rubbing wax on the surfaces that the draws will come into contact with.
    in this case it shouldn't matter how rough the timber you use is it just means you'll need to put on a little more wax.
    as for ilikedonuts_10:
    it depends on some factors as in, how thick you want the ply to be and how heavy the fridge is, and also how far out do you intend for the fridge to be able to slide out.
    i have seen actual sliders that you can buy intended for car fridges.
    or you can just make your own.
    what you need to worry about is just the bending moment (rotational force) that's acting on the ply at the edge of where the drawer hangs out.
    reinforcements are always helpful though but you may not need it when the ply is 19mm thick and you only want it to just slide out such that you can reach it with ease.
  5. #15
    334 Post(s)
    Hey guys,
    I am a cabinet Maker in a previous life and have made a couple of decent sets of drawers for the back of the 4B and 19mm Marine Ply would be fine if you were BUILDING A BOAT! or wanted to park your 4B on whatever you built!
    The stuff is Really heavy and very very over kill for what we want. With regards to i t being water proof? it is going INSIDE the car! Give it a coat of paint when your finished and they will be fine.
    I have used both ply and MDF and both work fine.
    For strength i have used 12mm for the body of each the drawers to save a bit of weight and the base plate and 15mm board for the bottom of each drawer and the top lid of the whole unit.
    15mm drawer bottoms gives you something to screw into as you should be fitting the drawer bottoms inside the drawer sides rather than just screwing them to the bottom of the drawers.
    I lined them with carpet from Bunnings and painted the outside of each drawer black and they look great when open and closed.
    I carry 30kg+ in each drawer regularly and over tough ground with No Problems ever.
    As someone said earlier, Glue and Screw everything and they will NEVER let you down.
  6. The Following 5 Users Say Thank You to MudRunnerTD For This Useful Post:
    AB (4th January 2011), Almost Dun (14th February 2011), Finly Owner (5th January 2011), twisty (21st July 2011), Woof (4th January 2011)
  7. #16
    Good advice MR, cheers!
  8. #17
    Legendary big_fletch's Avatar
    Oct 2010
    Tatura VIC
    Thanks for that MR, answered a lot of my questions Haha.. I will hopefully start a set of drawers soon, hope to have them done before vic meetup
    Qualified Auto-Electrician
    Apprentice Sparky
    Dont own a Patrol or any 4WD at the moment, hopefully will change into the future
  9. #18
    Oct 2010
    Tatura VIC
    Looking forward to seeing them Fletch. I love home made stuff.
    ill make sure i do a good job then for you plassy haha
    Apprentice Sparky
  10. #19
    Feb 2011
    Mid North Coast
    Hi When I purchased ply for repairs to my boat the marine ply was for the transom and for the floor I used a ply that was a lower grade of marine ply Marine ply has no voids and the lower grade does - even for your project the lower grade will be more than ample - I would stay away from MDF and weetbix boards no matter how well they are sealed unless you use fiberglass. Just my 2 cents worth.
  11. The Following User Says Thank You to szaf For This Useful Post:
    YNOT (13th February 2011)
  12. #20
    Patrol God Finly Owner's Avatar
    Jul 2010
    Waterford West Qld
    I say again cover sheets off ply wood packs at Bunnings, cheapest best buy.
