Page 1 of 3 123 LastLast
Results 1 to 10 of 28
Thread: When to lock Hubs
    Advanced PT Paul's Avatar
    May 2011
    Ipswich
    When to lock Hubs
    Recently learnt/ heard that you can have the hubs on lock all the time! It even helps with lube! Any thoughts?
    Aug 2010
    Lower Blue Mountains
    17 Post(s)
    I wouldn't and would not recommend it to anyone
    But have also heard you can leave it locked without causing damage
    http://www.4x4abc.com/4WD101/hubs.html
  3. The Following User Says Thank You to NissanGQ4.2 For This Useful Post:
    PT Paul (18th March 2012)
    Hardcore macca86's Avatar
    Jun 2011
    Brisbane again! whoo!
    leave them free on the black stuff lock them when engaging 4wd and you can leave them locked and go back to 2H if on the beach to save some fuel but you can bind the axles on the black stuff if you leave them locked
    Such is the rule of honour.
  5. The Following User Says Thank You to macca86 For This Useful Post:
    PT Paul (22nd March 2012)
    May 2011
    Ipswich
    Thanks NissanGQ4.2 I thought it was a no no as well. But found it written in black and white. How can there be debate about weather it does any damage etc. Either it does or it doesn't.
    May 2011
    Ipswich
    but if the front diff is an open diff and there is no driving power going to it how can it get bound
    Patrol Guru TimE's Avatar
    Canberra
    You can have them locked on the tar so long as you are in two wheel drive (2H), else as mentioned above you will suffer axle wind up with the potential to stuff axles and/or gearbox and/or transfer case.
    When hubs are locked in 2H you will hear more noise and you will use more fuel. (A hint for those using auto hubs is to reverse a few meters (in 2h) when finished fwding to ensure the auto hubs disengage).
    Can't see the point in locking hubs in 2wd unless the black stuff is very short between dirt stretches.
  9. The Following User Says Thank You to TimE For This Useful Post:
  10. #7
    May 2011
    Ipswich
    So it doesn't damage anything (in 2H) but may notice increase in fuel consumption and noise.
  11. #8
    May 2011
    Ipswich
    Thanks guys. I don't plan on driving to mexico locked but it's good to know I don't have to get dirty flippin' em back and forward on a dirty weekend.
  12. #9
    Hardcore the ferret's Avatar
    Sep 2010
    on the coast W.A.
    It just means that your front diff will be turning when there is no need, more wear and tear on the crown wheel and pinion, the bearings and the front uni's and cv's. as well as more fuel.
    Cheers, the ferret.
  13. The Following User Says Thank You to the ferret For This Useful Post:
  14. #10
    Banned Bigrig's Avatar
    Oct 2010
    South of Brissy, QLD
    I do it if I haven't been off road for a while - keeps the oil moving, gears oiled etc, but I don't leave them in though ...
  15. The Following User Says Thank You to Bigrig For This Useful Post:
