Page 4 of 6 FirstFirst ... 23456 LastLast
Results 31 to 40 of 55
Thread: TB42 Tappet Adjustment
  1. #31
    Hardcore
    central coast nsw
    Ok, no one has asked the ? so I will.
    what is the, where is the valve train wear accruing.
    what to look for?.
    Why do these engines have a noisy valve train?.
    what should be replaced.
    cam, lifters, p-rods, rocker or valve?.
    actually starting a new thread for all to see.
  2. #32
    Advanced Rosco's Avatar
    Thanks fixer, never heard of that, but never worked with solid lifters or roller rockers either.
    Our TB42 rockers work the same as roller rockers. We just dont have the roller on the tip to roll over the valve tip.
  3. #33
    Beginner terrors4's Avatar
    Dongara WA
    Great info, Thanks
  4. #34
    Kinglake Victoria
    great info thanks.
    Cheers Andrew
  5. #35
    Hello, new to the forum. my name is nick and im from warragul in victoria! (will go and do a proper introduction with pictures and what not when i get home )
    i Have a mav, dual fuel and once it gets warm, i.e driving for 15 or so minutes, it produces a spasmodic sort of miss, "pops" and the revs drop on the tacho. its not enough to lose speed but is enough to scare the shite out of me. i can hear the tappets, quite loud. would this be causing the vehicle to miss?
    Thanks,
    Nick
  6. The Following User Says Thank You to goodie For This Useful Post:
    SiRGsR (6th June 2012)
  7. #36
    Ballarat
    mine was doin that mate i ditched my point set up in the dizzy and went to a pertronix set up
  8. #37
    thanks patch697 for the info on tappet adj that is going to help alot .gazz from tamborine
  9. #38
    Nov 2013
    Adelaide, SA
    I know this is an old thread and id get slammed on the other forums i'm on,
    but does anyone know the adjustment for a cold engine? TB42
  10. #39
    Quote Originally Posted by MikeBossyBos View Post
    Dont worry, you won't get slammed here. I must admit, I was always under the impression that adjustment should be done whilst the engine was warm. So not sure if there are cold settings. Hopefully if someone has done it, they may be able to help.
  11. #40
    Patrol God taslucas's Avatar
    Aug 2011
    North West Tas
    56 Post(s)
    I have this from a Haynes manual:
    TB42 valve clearance:
    COLD:
    Intake 0.20(mm), 0.008(inch).
    Exhaust 0.20(mm), 0.008(inch).
    HOT:
    Intake 0.38(mm), 0.015(inch).
    Exhaust 0.38(mm), 0.015(inch).
    Note: "cold" is 20 degrees C.
    I had a mate help me adjust mine last year. About a 40 minute drive to his place so we set it for the hot adjustment. It made a noticeable difference with power and economy.
    Hello from Under Down Under!
  12. The Following User Says Thank You to taslucas For This Useful Post:
    Clunk (13th November 2013)
