Results 1 to 10 of 12
Thread: Turn Lamp LED's
    Patrol Guru White Elephant's Avatar
    Sep 2011
    Perth,WA
    Turn Lamp LED's
    Folks,
    So I bought a bunch of LED globes to replace the standard incandescent ones in the old girl (GQ) The question I have is that when I put the White LED globes into the Turn Lamps (not indicators, I am talking about the static white ones in the fenders) they don't work at all.
    The bulbs aren't faulty, becuase I tested them in the reverse light sockets. The standard globes in both the reverse lights and turn lamps appear to be the same 15mm bayonet type fitting.
    I understand that a LED specific relay needs to be used for the indicators in particular, but the turn lamps are not intermittant so I didn't think this would affect them, or the current draw.
    Any ideas please?
    95 GQ RX RD28T LWB Wagon and stuff. www.levelsevenband.com
    Aug 2010
    Lower Blue Mountains
    17 Post(s)
    I have know idea sorry, but have 2 ask....... are you in the band in your signature link???
    Advanced philfree's Avatar
    Oct 2011
    Gympie, QLD
    Hi they should be the same as the reverse lights have you by chance changed all the indicators to led's
    Banned
    Apr 2011
    Greenbank QLD
    25 Post(s)
    I'm not sure how those cornering lamps are wired up, but the LEDs are polarity biased
    So it's possible the way the light socket is wired up is preventing the LEDs from working.
    With standard bulbs it doesn't matter, they will work with power and earth supplied either way.
  5. The Following User Says Thank You to Yendor For This Useful Post:
    White Elephant (22nd February 2012)
    Patrol Freak BillsGU's Avatar
    Jul 2010
    Thurgoona
    7 Post(s)
    LEDs are diodes and they are polarity sensitive. Try turning them around as the negative and positve terminals may be wrong way around.
  7. The Following User Says Thank You to BillsGU For This Useful Post:
    Sep 2011
    Perth,WA
    Indeed I am mate! Someone finally noticed the link! lol!
  9. #7
    Sep 2011
    Perth,WA
    Quote Originally Posted by philfree View Post
    G'day philfree, I haven't changed the indicators out yet, I need to pull all of the bulbs out to see what I need (I haven't really had the time) cos there are a lot of them, includng the ones in the bullbar.
  10. #8
    Sep 2011
    Perth,WA
    Thanks mate, these particular ones only have a single terminal at the bottom, half the reason it has left me stumped.
  11. #9
    Banned
    Apr 2011
    Greenbank QLD
    25 Post(s)
    With your voltmeter, put the positive probe on the single terminal in the bulb socket and the negative probe on the inside of the bulb housing.
    With the light turn on does the meter read positive 12 volts or negative 12 volts?
  12. The Following User Says Thank You to Yendor For This Useful Post:
  13. #10
    Sep 2011
    Perth,WA
    I'll have to check it out later on, and will let you know. What should it read for the LED's to work?
