Page 5 of 7 FirstFirst ... 34567 LastLast
Results 41 to 50 of 68
Thread: Gu led dash lights
  1. #41
    Expert BearGUST's Avatar
    Apr 2011
    Mornington Peninsula
    Any change to a safety item such as a speedo could technically be a concern as there are specific design rules that apply.
    You'd be very stiff to ever get done though!
    Early 'sports' level VE's had red illumination which was a bit hard to read at times, they kept the red theme but changed the gauges to white as it was heaps clearer to read.
    I am here: http://maps.google.com/maps?ll=-37.845422,144.946684
    GUIII ZD30 Manual Wagon, OME 2" lift, 33" BFG AT's, Snorkel, Chip, 3" Redback Exh, Dual Batts, etc.
    KEEP OUR TRACKS LITTER FREE!
  2. #42
    Apr 2011
    I ordered a set of the white LED's and fitted them tonight, not impressed at all so have pulled them back out.
    They weren't white, and they weren't bright. I'll get some new incandescent globes tomorrow as the ones I pulled out were pretty black.
  3. #43
    Banned Bigrig's Avatar
    Oct 2010
    South of Brissy, QLD
    Haven't done my 'blueys' yet, that's something for this weekend ...
    Bummer on the white jobbies though!!
  4. #44
    Expert patrol2.8's Avatar
    Nov 2011
    vic
    Bigrig hows the install going
    Theres only one thing tougher than my truck............. YES DEAR GOING TO DO THE LAWNS NOW
    WARNING: Towballs used for recoveries,can and do kill people and damage property
  5. #45
    Oct 2010
    Quote Originally Posted by patrol2.8 View Post
    Sorry mate, did them last week - they were easy to do and look pretty good. Nowhere near as brig as the standard bulbs, but still good (ish). The big bonus is on night driving in non built up areas - softer light that seems to 'interfere' less in your peripheral vision ...
    My only want would be that they were maybe a little brighter, and that you could still use the dimmer switch for them (mine don't dim/brighten) so not sure on that one ...
  6. #46
    Nov 2011
    vic
    big rig good point on dimmer will check and see if mine dim just did mine dim down without a problem not sure why yours wouldnt
  7. #47
    476 Post(s)
    need to take the top part of the plastic around steering colum ...
    Do I need to remove this right out? As I have unscrewed it but for the life of me can't get it out. The steering wheel is in the way. Unless I have to hold my tounge a certain way. I have the steering column lowered as far as it will go too...
  8. #48
    Expert altech's Avatar
    Nov 2011
    Rupanyup, 3388, VIC
    Hi Guys, did mine when patrol2.8 did his , I left out the trip meter and clock as there where white , here a pic at night cheers Alex
  9. #49
    Nov 2011
    vic
    altech looks good can the brightness be adjusted as i know of a few that have lost that with the leds
  10. #50
    476 Post(s)
    Guys. The new LED globes you have are they just the globe and they fit into the little plastic socket or they the globe and socket all in one? I see you that they are listed on Ebay for GU series one only and then I see them listed for GU patrols...I fail to see what the actual difference is.
