Results 1 to 10 of 15
Thread: GU III pulling to the left
    Advanced myzathreeby's Avatar
    Feb 2012
    Palmwoods QLD
    had the GU III a couple of weeks
    It pulls slightly to the left on normal roads.
    I have searched Google, and it appears to be quite a common problem.
    Solutions range from replacing offset pins with different degrees of offset, to driving on the right hand side of the road camber....
    This does actually work, when overtaking the wheel corrects itself beautifully on the wrong side of the road. Maybe it is set up for RH side driving. Though I can't think this would be so.
    Just wondering if anyone else has this problem, and maybe a solution.
    Thought about lowering the RH side tyre pressure marginally and increasing the LH side to provide a differential in drag to offset the pull to the left
    Is that thinking outside the square, or what..
    Feb 2012
    Palmwoods QLD
    Sorry, meant to put this under 'general mechanical'
    334 Post(s)
    I did this mod to the left side about 2 years ago and it the best mod i have done to the car
    Safe-t-steer - GU Patrol
    Do it, no regrets.
    Expert Russell1974's Avatar
    Are the wheel bearings ok king pin bearings ok no mud stuck or caught in the wheel an uneven brake shoe
    Feb 2012
    Palmwoods QLD
    Hi Mudrunner
    I reckon this sounds like the right solution.
    pretty good website, very good instructions.
    Did you do the job yourself ?
    I would have tackled it when I was younger, might still give it a go' Cheers mate.
  6. #6
    Feb 2012
    Palmwoods QLD
    Hi Russel
    The truck is in pretty good nick and there is no wear, don't think it has done much offroading, and there is no mud (not yet anyway)
    Good idea to check these thing though
    Cheers John
  7. #7
    Feb 2012
    Palmwoods QLD
    Thanks Aaron
    I will look into this also
    I'll try swapping tyres around first and go from there, then check toe in and then look at buying offset bearings or a draglink
    It feels wrong having to pull on the wheel all the time, even slightly,
    It would have to increase tyre wear over time.
  8. #8
    334 Post(s)
    Hey John, nah mate I had a leaking axle seal as well so took the opportunity to get that done at the same time, just could not be shagged. Plus the king pin bearing race can be a bugger so I gave it to a bloke to do.
    It was actually his call to fit them and he had done many, he was able to then make the adjustment necessary given that it is variable.
    Your problem is not a Toe problem but rather a neutral camber setting that can't deal with the significant camber on roads in Australia. A drag link will help with your alignment if you have a lift. They are actually mainly used to straighten the bloody steering wheel though. It really won't sort your problem out though. Didn't fix mine.
    This is a very common problem but not to every Patrol! Lots of then though and Nissan should fit this camber kit for free instead of trying to blame round abouts for the tyre scrub.
    Fit the kit and get them to do the alignment adjustment to the camber while they are at it. It's a cheap and affective fix.
    AAA+
    Sent from my iphone
  9. #9
    Feb 2012
    Palmwoods QLD
    Cheers Mudrunner
    Checked the tyre pressures to start off with, (first time since I bought it) found both front tyres to be 39 psi they should be 29.
    So fixed that pronto.
    That has improved the pull marginally, Then I tried putting 34 psi in the left side and leaving the right side at 29.
    That made it a bit better again, but not enough. I have noticed the front right tyre is feathering the tread on the right hand edge. I guess this will be due to the fact I am constantly pulling the car to the right to keep it straight.
    Looks like the camber kit and drag link will be the go,
    Cheers John
  10. #10
    Feb 2012
    Palmwoods QLD
    Further Developments..
    A couple of weeks ago I swapped the wheels around and put the best ones at the front. This improved the pull to the left slightly, but not enough to be happy.
    A couple of days ago, while driving in the wet, I heard a noisy front wheel bearing on the front left.
    Bought a new kit and fitted it today.
    Took the bus for a drive to check it out (like you do) and guess what.... The pull to the left has disappeared.. Bloody fantastic.
    before I took the wheel off, I also noticed it was also a bit loose ( Wobbling on the axle)
    So I figured the bearing was causing a bit of drag, and also being loose has probably changed the camber enough to have an effect.
    To be honest, I could not imagine the car would ever have come out of the factory, with a pull to the left, so logically it would indicate that something has changed since then.
    That change was a faulty wheel bearing.
    So, Problem fixed....Yeah..
  11. The Following User Says Thank You to myzathreeby For This Useful Post:
    Silver (25th March 2012)
