Results 21 to 30 of 33
Thread: MaZ's Truck
  1. #21
    Expert Mazodude's Avatar
    Aug 2011
    Forest Lake, QLD
    No my mate is knocking them up. High hats are to lift it off the floor.
    "Gunter" - 1993 Nissan Patrol GQ DX II, 6cyl 4.2L Diesel. 2" Lift EFS suspension. 33" Mickey Thompson MTZ (285/75 R16). Warn Winch
  2. #22
    Expert Forced Offroad's Avatar
    Apr 2011
    Logan/Daisy Hill
    Quote Originally Posted by Mazodude View Post
    What do I have to watch for on the rear window?
    The rails and also there are 2 drain hole in the window from memory. They can block up then water gets into the welded window pinch seems and starts rust around the bottom of the rear window under the the window rubber seal. The window can be poped out easy enough, to check or repair. Also rust likes to start under the back doors wheel arch. You can remove the rear flare and then the hub plastic trim to check. Also common is the bottom main rail on the car. Unfortunately the qg's are coming up to 20 yrs old but there still the best 4b ever sold in Aus.
    Cheers jay
    FORCED OFFROAD
    Built by NISSAN Powered by HOLDEN Perfected by ME "hulksta"
    http://www.youtube.com/watch?v=3GX2M...layer_embedded
    http://www.nissanpatrol.com.au/forum...Gq-v8-daul-cab.
  3. The Following 2 Users Say Thank You to Forced Offroad For This Useful Post:
    Ben-e-boy (11th December 2011), Mazodude (11th December 2011)
  4. #23
    Aug 2011
    Forest Lake, QLD
    just a quick update.
    Bday is coming up and a new hid spot light is on order
    got to love the guys a torq4x4
    pics to follow.
    also wired up a in-cab electric winch controls.
  5. The Following User Says Thank You to Mazodude For This Useful Post:
    rusty_nail (2nd February 2012)
  6. #24
    looking forward to it mate
  7. #25
    Aug 2011
    Forest Lake, QLD
    as promised.
    Spot and spread lights, just plain 100w halogen atm
    should be getting the hid spot from torq4x4 on monday or tuesday
    in cab winch controls:
    just a simple two switch layout. the first is to stop accidental usage of the winch if not flipped.
    use a power extension lead for the wires that go back to the winch solenoids.
    Still have it hooked up so I can use the hand control if needed.
  8. #26
    Banned Bigrig's Avatar
    Oct 2010
    South of Brissy, QLD
    Nice old mate ... so when we going for a play?? And a beer obviously!!! lol
  9. #27
    Aug 2011
    Forest Lake, QLD
    well I am itching for a play. just been so busy with life.
    it also has not helped that it has been way too wet to go off road. (yea I know, what?)
  10. #28
    Oct 2010
    Are you coming out to Springs in early March??
  11. #29
    Aug 2011
    Forest Lake, QLD
    I didn't know it was on.
    Note to self: read forum more often.
    I will have a look
  12. #30
    Aug 2011
    Forest Lake, QLD
    Something just arrived. I wonder what it could be.... ?
    Thanks Torq4x4
