Page 12 of 14 FirstFirst ... 1011121314 LastLast
Results 111 to 120 of 139
Thread: Snicko doing the NADS
  1. #111
    Legendary snicko's Avatar
    Apr 2011
    Eyre Peninsula SA
    Quote Originally Posted by bastardo View Post
    Great read on here SNICKO. At the moment I'm organizing all the treats for the patrol. Just gotta find a shop in Brisbane. Any one with a reccomendation ?
    Took me ages to gather the info, get the bits and then get them fitted. When you start post up a thread of your progress as everyone has different experiences.
    Look forward to reading yours.
    GU Patrol: 3LTD :- The cheapest option is to buy the right thing the first time! - YEP WORKS FOR ME!!
    Front and Rear "LOCKED" WOO HOO !! squeal, scream, squeal toot toot !! hahahaha
    NISSAN PATROL.com.au .......stickers........done by Snicko.......I know you want one....
    http://www.nissanpatrol.com.au/forum...screen-Sticker
  2. #112
    Banned
    Apr 2011
    Greenbank QLD
    25 Post(s)
    Hi Snicko,
    I was talking to two blokes on the weekend, both had cross country intercoolers fitted and both had problems with the metal plate that is fitted under the bonnet for the scoop, rubbing on the intercooler (back passenger side).
    Might be worth checking yours.
    Cheers Rodney
  3. The Following User Says Thank You to Yendor For This Useful Post:
    snicko (13th March 2012)
  4. #113
    Apr 2011
    Eyre Peninsula SA
    Hi Snicko,
    Cheers Rodney
    Thanks Yendor for thinking of me I will go out and check.
    Did the guys say how many km they had done since the intercooler was fitted?
    I read somewhere that with a bigger intercooler the scoop needs to be replaced and the suggestion was the one off the Holden Rodeo.
    EDIT:
    Just checked and yes mine has small rub marks in the same spot.
    Looks like I will have to do some more research into a bigger scoop.
    Thanks Yendor for the heads up .
  5. #114
    Banned
    Apr 2011
    Greenbank QLD
    25 Post(s)
    Sorry I don't know how many Ks they have done since being installed.
    I know one has only just been installed and it didn't take very long for it to wear a flat spot in the intercooler.
    They both run standard scoops.
    One guy removed the plate altogether and the second guy glued a strip of rubber/foam along the edge of the intercooler.
    Lets un know how you go.
    Cheers Rodney
  6. The Following User Says Thank You to Yendor For This Useful Post:
  7. #115
    Bannockburn
    Hi all, just new here, where will i find some installation info here for NADS, I have a 2006 GU (Does this make it a series 4 ?), Direct Injection, Auto trans & pretty much stock at the moment, and does my model still need/benefit having these mods done.
    Thanks in advance for any info..
  8. #116
    Quote Originally Posted by Forest1970 View Post
    If its the 3ltr then yes you need to NAD up.
    What you will need :
    * Dawes : From the US or me, I'm a bit dearer but its a lot quicker
    * Needle Valve : Dependable disty's in Adelaide
    * Provent 200 catch can : Ebay The $170 priced one.
    * EGR Plate : The Ferret does'em
    * Pyro bung : Zorst shop
    * assorted hose and fittings : Hose shop
    * Boost and EGT guage (this needs to be fitted before anything) : Anywhere you fancy
  9. #117
    Patrol Guru Drew's Avatar
    Western burbs of Melbourne
    Any updates on your travels with finding a bigger scoop snicko ?
    2008 GU 3.0 CRD Auto - Life's too short to eat bad food.
  10. #118
    Just recently fitted NADS to my 4x4 with Forum help {thanks} You'll find your EGTs will go down if you increase boost.
    Max around 18 psi, Boost controls the EGT. If you can't acheive enough boost you may have to stretch spring to up
    the boost.
  11. #119
    That looks like it would suck the crotch out of a low flying duck!
  12. #120
    Yeah can really feel the difference, just upset my intercooler not leaking yet, would like to feel what happens with the larger IC.
    Pricey but well worth it IMO. 4x4 was a slug [normal] when I took it off to be sprayed, LOL
    WRX scoop look ok too, you might find the modded 4x4s get heat block, as the heat can't escape from the engine bay
    Chances are if you have a GU with a bullbar the scoop doesn't work.
    see the front vane inside large scoop.
    Pass the duck I'll give it a go lol
    Is this one of those 5 in 1 threads you hear about??
