Results 11 to 20 of 34
Thread: Fuel economy ST Patrol GU ll manual 3l turbo.
    Patrol God Sir Roofy's Avatar
    TRAFALGAR VIC
    35 Post(s)
    Quote Originally Posted by beargust View Post
    a question for those getting 11l/100km - are you cars standard? If not, what mods have you done? I'm pretty happy with 13's, would be rapt to get it down closer to 10's!
    id like to know as well
  2. #12
    Sep 2011
    Melbourne, Vic
    me to, by the way what boost are you running when sitting on 110 for manuals. at 2850 rpm on the flat i'm sitting at about 12psi
    Phil
  3. #13
    TRAFALGAR VIC
    35 Post(s)
    Quote Originally Posted by philws View Post
    me to, by the way what boost are you running when sitting on 110 for manuals. At 2850 rpm on the flat i'm sitting at about 12psi
    cheers
    phil
    im running at about 10 psi
  4. #14
    Sydney
    running around normally , @100kph, 7.2psi, 345C
    @110kph, 8.2psi, 355C
    this gives me around 10.8l/100kms around sydney including stop start in peak hour traffic.
    I did a trip up to the barrington tops over xmas and with the roof rack loaded and towing the trailer loaded with camping gear i wound the boost up a bit and averaged 12.7l/100kms for the trip.
    if you want better fuel figures:
    1) drive it a bit nicer
    2) lower your boost (but the less boost the higher egt's go so you need to find a good balance)
  5. #15
    Oct 2011
    Gold Coast
    You guys are all talking about adjustable boost - enlighten me. What do I have to do and how much would it cost?
    Wal
  6. #16
    Dalton, iv got a 02 3L and I average out about 11.3L per 100km's doing a mix of town/highway and a little beach. It's stock standard and am super happy with it. Take it easy
  7. #17
    Sydney
    Quote Originally Posted by holden4th View Post
    the dawes and needle valve mod. takes boost control away from the ecu and you can control how fast the turbo spools up and what the max boost pressure is reached.
    Also commonly known as NADS, nissan anti destruction system. You also need boost and exhaust temp (egt) installed to be able to monitor the settings
  8. The Following User Says Thank You to speedy_1 For This Useful Post:
    Kram (13th January 2012)
  9. #18
    Gold Coast
    My 2006 GU does around 13/100 in general town driving. Best ever unloaded on highway is 10--11/100. Tow camper trailer and push a bit, it is 15/100.
    BTW if you plan sand and stuff, plan for 20 to be safe, but probably you will only use 15
    Hope this helps.
  10. #19
    Expert teleman's Avatar
    May 2011
    Montrose
    Quote Originally Posted by BearGUST View Post
    A question for those getting 11L/100km - are you cars standard? If not, what mods have you done? I'm pretty happy with 13's, would be rapt to get it down closer to 10's!
    My car is standard apart from... dual batteries
    Sport bucket seats in front
    2"lift
    Heavy duty nissan tow pack
    cruise control
    Thats it. I treat mine with a lot of care though. Gotta Love It.
    2001 GU series II 3.0 TD.
    2" lift
    Dual Battery System
    ARB Snorkel
    Awesome car!!!!
  11. #20
    Springwood, Brisbane
    I have a standard 2009 GU 3.0 L, and get about 11L / 100km. It seems to be about the same around town and on the highway, I'm guessing because it is not very aerodynamic.
