Results 1 to 5 of 5
Thread: Brake Fluid
    Brake Fluid
    Hi all,
    I wanted to replace the brake and clutch fluid. In the shops I can only find DOT4.
    Is it OK to replace the DOT3 by the DOT4? What about the clutch?
    Smile
    Sep 2011
    adelaide
    18 Post(s)
    Dot 4 is ok to use in both brake and clutch the spec`s of dot 4 are just an improvement over dot 3.
  3. The Following User Says Thank You to pearcey For This Useful Post:
    patch697 (7th January 2012)
    Expert NewDan's Avatar
    Oct 2011
    Hey there Smile, I had an issue last week while touring, looked under the hood and no fluid in the clutch at all...well just a little, rang my mechanic who lives and breaths 4wds and he said not to worry about DOT3 or DOT4, just to use anything I can get and it would be fine, hope this helps, Dan.
  5. The Following User Says Thank You to NewDan For This Useful Post:
    Banned
    I use Castrol Hi temp. Its expensive compared to regular brake & clutch fluid but given the close proximity the clutch slave is to the secondary pipe & the work we put these big old girls through I thinks its a wise investment.
  7. The Following User Says Thank You to patch697 For This Useful Post:
    growler2058 (7th January 2012)
  8. #5
    Jul 2011
    Brissy
    toyotas seem to be the only ones that recommend dot 3 only. ive heard of people putting dot 4 in the brake master and it swells the seals inside. ended up costing them 4 grand to replace it as the abs unit is incorporated in it (100 series landcruiser)
