Results 1 to 10 of 14
Thread: Front wheel spinning while 4wd is disengaged
    Aug 2010
    Lower Blue Mountains
    17 Post(s)
    My dad the other day tried doing a stall test on his 91 GQ ( auto ) and the rear and front drivers side wheels started 2 spin, He has auto hubs which where in the auto position.
    Which one would likely 2 be having issues...... the auto hubs or transfer case?
    Todd
    Banned
    I'd be thinking the transfer case mate cos if its in 2wd & your getting drive to the front axles then there's something a miss there for sure.
    Look at the selector first off as there's not much that can go wrong inside a transfer case itself.
    Aug 2010
    17 Post(s)
    Quote Originally Posted by patch697 View Post
    thanks mate, yeh at first he thought auto hub but then he thought about it some more and decided must be an issue with the transfer case, he just wanted a second opinion before he starts ripping things apart
  4. The Following User Says Thank You to NissanGQ4.2 For This Useful Post:
    patch697 (14th December 2011)
    Sep 2011
    Abbotsford , BC Canada
    It is a fairly well known issue with the t-case and auto hubs using standard 80W90 gear oil. The gear oil caused enough drag to turn the drive shaft and to engage the auto hubs. There are few solutions.
    1) replace auto hubs with manual hubs
    2) mod auto hubs to only be manual hubs (there are a couple threads on this in that other Patrol forum)
    patrol4x4.com/forum/nissan-patrol-gu-gr-10/hubs-converting-autos-manual-6524/
    3) put in a synthetic oil - like Redline MTL
    4) or put in ATF (this is what Nissan decided as the solution with post 91 models)
    In my auto, I run the same ATF in the Tcase and Tranny. On my 5 spd, I run Redline in both the Tcase and Tranny.
    NOTE: DIRECT LINKS HAVE BEEN REMOVED DUE TO PATROL4X4's VIRUS PROBLEMS, ENTERING THE ABOVE LINK INTO YOUR BROWSER YOU DO AT YOUR OWN RISK
    KIND REGARDS
    FORUM MANAGEMENT
  6. The Following 3 Users Say Thank You to canuck For This Useful Post:
    MudRunnerTD (16th December 2011), rottodiver (16th December 2011), Silver (16th December 2011)
    334 Post(s)
    ^^^ Great post! hope is sorts out Tod's problem. Cheers
    RIP - valued member and true gentleman of this forum that will be missed by many! Silver's Avatar
    Feb 2011
    Brisvegas
    Funny, one of the conversations last night at the Christmas party Scott and Sandra hosted last night was Patrol problems.
    Some present said they were not problems, they were features - Power Windows, Aircon, and then pick next - 5th gear shaft problems, early 3 litre problems, TB42 head problems at high ks were all described as 'features'.
    I kinda struggled with seeing any of those as 'features'. A viscous coupled part time full time 4wd system might however be classed as a feature :-)
    "As a boat owner and a four wheel drive owner I feel like a pelican: every where I look I see a big bill in front of me”
  9. #7
    Banned
    Quote Originally Posted by canuck View Post
    2) mod auto hubs to only be manual hubs (there are a couple threads on this in that other Patrol forum: patrol4x4.com/forum/nissan-patrol-gu-gr-10/hubs-converting-autos-manual-6524/
    Although whats posted in the quotes above is good factual info, I was under the impression Todd's dad was stall testing he's Rig there for it should have had all 4 wheels on the ground & that theory wouldn't apply.
    Can you confirm this for us please Todd?
  10. #8
    Aug 2010
    17 Post(s)
    Thanks for the post
    He uses ATF in his Gearbox and Transfer case, Its the same oil I run in my 92 GQ Gearbox and Transfer case ( No probs for me so far ). I don't see it as an auto hub issue and my old man doesn't really use his 4b as a off road machine so don't see any real need to convert 2 manual hubs or mod the auto hubs 2 be manual.
    Modding the auto hubs to manual can also be found on this forum here: http://www.nissanpatrol.com.au/forum...ight=auto+hubs
    Thanks 2 Tony ( Ynot ) for that usefull post. I have modded my auto hubs over to manual
    Spot on Paul, all four wheels on ground stall testing, seen the marks on his driveway this arvo where both rear and front passenger wheels spun.
  11. #9
    Banned
    Quote Originally Posted by toddrhind View Post
    Head for the Tcase mate as a starting point.
  12. #10
    Aug 2010
    17 Post(s)
    Thanks mate, sending you a PM
