Results 1 to 10 of 17
Thread: rear main seal
    Expert ozzyboy's Avatar
    Oct 2011
    springwood, qld
    rear main seal
    heyas
    I got the verdict yesterday that the thrust bearing is almost shot, need to replace over the next month or so.
    At the same time, will replace the clutch ( or atleast have a crack at it myself )
    My question is, i have heard the rear main seal can be replaced whilst the box is out.
    Is this true, and is there much too it, or best left to a mechanic?
    As far as i know, there is nothing wrong with the seal, but i'm thinking best to replace if i got access.
    Oh and if it differs, it is a 4.2 petrol / gas efi gq
    cheers
    ozz
    Perth WA
    63 Post(s)
    Hey mate I just got my Q back from the mechanics today, new heavy duty clutch and rear main engine seal replaced $1,757.49
  3. The Following User Says Thank You to Woof For This Useful Post:
    ozzyboy (14th December 2011)
    Feb 2011
    Brisvegas
    consider replacing the input shaft seal on the gearbox at the same time - if it can be replaced without dismantling the box now is the time to do it, esp as it will be pushed and pulled in strange directions while mating up the box/bell housing to the block.
    "As a boat owner and a four wheel drive owner I feel like a pelican: every where I look I see a big bill in front of me”
  5. The Following User Says Thank You to Silver For This Useful Post:
    Quote Originally Posted by The Dogman View Post
    Oh god....The misses is going to kill me when I mention how much money I need to fix this clutch...lol
    Oct 2011
    springwood, qld
    i got quoted 1100 for an exedy hd clutch fitted.
    1100 takes away from mods so i wanna try myself
    Banned Bigrig's Avatar
    Oct 2010
    South of Brissy, QLD
    Quote Originally Posted by ozzyboy View Post
    Want some help?? Sounds like a working bee on your rig to me!!! lol
    Happy to assist - even if that means having a beer and pointing at stuff!!
  9. The Following User Says Thank You to Bigrig For This Useful Post:
  10. #7
    Patrol Guru rottodiver's Avatar
    Nov 2011
    Perth
    it aint too bad a job to do it yourself.... just everything is so heavy..... nothing two trolley jacks wont fix, a little fidly putting the box back in, i pulled the transfer case and gear box out as one!!!! i believe some people do split them...... also make sure you get the flywheel machined!!!!!
    Scotty
  11. The Following 2 Users Say Thank You to rottodiver For This Useful Post:
    growler2058 (13th December 2011), ozzyboy (14th December 2011)
  12. #8
    Oct 2011
    springwood, qld
    hmm ok.
    so looking at the above, i have gone from replacing thrust bearing to
    thrust bearring
    clutch
    flywheel machined
    rear main seal and
    input shaft seal ........
    don't plan on driving home bigrig, thats a lot of beers and pointing at stuff :P
    ozzy
  13. #9
    Nov 2011
    Perth
    hmm ok.
    thrust bearring
    clutch
    flywheel machined
    rear main seal and
    ozzy
    isn't this the typical life of a 4wd owner
    Scotty
  14. #10
    Feb 2011
    Brisvegas
    Bob over the Road - as in Doreen and Bob who some met at LCMP gave me a good tip years ago when I replaced the clutch in my MQ.
    The tip was to get some longer bolts with the same thread as the bell housing bolts, cut the head off, and cut a screw driver slot.
    One can be screwed in on either side of the block, and can be used to guide the bell housing and block into alignment
  15. The Following 3 Users Say Thank You to Silver For This Useful Post:
    canuck (14th December 2011), ozzyboy (16th December 2011), Robo (7th January 2012)
