Results 1 to 10 of 17
Thread: Leaking Injector Pump - GQ TD42
    Hi All,
    I have had a leak in my injector pump for a month or so now. It hasn't leaked much but It's just starting to get worse now and It's time to fix.
    I thought the leak was on the side but after degreasing and drying off I have come to the conclusion It's leaking from all around the top so assuming my O-Ring seal on the top cover needs replacing.
    Just a quick one, has anyone done this and can give some advice?
    I assume I can replace the O-Ring without taken the pump off.
    Or am I just better off taking to a diesel shop and paying them to replace it. I wouldn't imagine it being over $200...Having saying that I would prefer to keep the $200 in my skyrocket...lol
    Below are some photos of the leak. I originally thought it was on the side as in one of the pics taken underneath looking up at the side but after cleaning it all I did notice it leaking at the top on the other side of pump as well which indicates the entire top seal is gone.
    Any other advice appreciated!!!
    I understand that this only a band aid fix and after replacing the gasket may open up more leaks in other areas but a new pump is not a cheap purchase...lol
    Patrol God Finly Owner's Avatar
    Jul 2010
    Waterford West Qld
    if the leak is in the seats of the pump under those fuel lines, they can be done without pump removal by you. I am assuming(bad thing to do) that they ar similat to mine. The seals are a cooper seal and can be purchased from any reputable diesel injector/pump service shop. They should give you instructions for fitting and tensions. Less than $100.00
    Tim.
  3. The Following 2 Users Say Thank You to Finly Owner For This Useful Post:
    AB (26th July 2011), MudRunnerTD (12th December 2011)
    Thats exactly what I want to hear!!!....lol
    Cheers Timbo!
    The delivery valves are on the back of the pump and your leak appears to be from the top of the pump. Then again, I hope Tim is right because that would be so much easier to fix.
    Tony
  6. The Following 2 Users Say Thank You to YNOT For This Useful Post:
    bobby-didge (22nd February 2012), gorpon (5th April 2026)
    Jul 2010
    Waterford West Qld
    Quote Originally Posted by YNOT View Post
    Tony
    I was going by the drip? I thought I was looking at.
    No, your right Tony...I thought it was down there too but actually I found it leaking at the top as per the other photos so your right, I wasn't concentrating properly and unfortunately it is at the top and is most likely the O'Ring rubber seal for the top cover.
    I have been reading about this problem a lot today and It's a common problem with older engines and the rubber seals with todays Diesel fuel.
  9. #7
    Jul 2010
    Waterford West Qld
    Hopefully still not too expensive.
    Tim
  10. #8
    adelaide
    hey buddyhow you going, ive got the same prob. with my diesel pump atm, just wondering how you went with yours and what it cost you in the end???
  11. #9
    Quote Originally Posted by bobby-didge View Post
    I just saw your other thread...haha
    Yeah mate I actually didn't fix mine myself but apparently It's a fairly easy job if It's the top seal.
    I was getting my turbo tuned so I just gave it to the guy to do in one shot and I think it cost arond the $200 mark....Its been fine since!
  12. The Following User Says Thank You to AB For This Useful Post:
    bobby-didge (15th December 2011)
  13. #10
    adelaide
    lol, well if its the top one ill give it a go, I just got to clean it up and hope its leaking from the top, lol
    thanks for the feedback.
