Results 1 to 10 of 17
Thread: Damn I damaged my fuel tank
    Expert xtreme patrol's Avatar
    Sep 2010
    Lakes Entrance
    My truck which i call Jinxed has lived up to its name
    After driving up a very difficult track on the weekend i noticed that the contents of my long range sub tank was dumping its full load of fuel 80lts of it grrrr
    After looking at it we all come over the conclusion that the tail shaft has flexed sidways under stress and given the tank a wack
    So the tanks out already and is going the the welders to get fixed and some extra angle iron over the edge
    but how do i stop it from happening again ??
    One thought is to put in some adjustable panhards in and move the diff over a little as the lift has moved it over towards the tank anyway (Not much though)
    The other is that the uni has a large ring around it (see pics) that i have not seen on other patrols so i would need a different uni or tail shaft?
    GU PATROL TB45 | 3" FLEXY LIFT WITH DROP BOX'S | 7" TOUCH SCREEN RUNNING OZIEXPLORER | 33" MT MTZ ON MT SIDEBITER RIMS | XROX TUBE BAR | TIGERZ11 12000lb WINCH
    Aug 2010
    Lower Blue Mountains
    17 Post(s)
    ouch, did you loose it all?
    Sep 2010
    Lakes Entrance
    Yep the whole 80lts of it .... NOT HAPPY
    Patrol God nowoolies's Avatar
    Perth
    bugga ....bugga ....and bugga
    what a mongrel of a trick , you gunna have to drop the tank out ?????
    is it the main or a reserve
    HELL NO !!!!!!
  5. #5
    Sep 2010
    Lakes Entrance
    Quote Originally Posted by nowoolies View Post
    Yeah Tanks out and washed out ready to be welded and it was my long range sub tank and my only petrol tank as im on gas
  6. #6
    Jul 2010
    Waterford West Qld
    Still becareful, even after washing out fuel tank, unbelievable how much fuel vapuor will be in there! Safe way is to pump carbon dioxide into tank while welding.
    Tim
  7. The Following 2 Users Say Thank You to Finly Owner For This Useful Post:
    Maxhead (1st November 2011), xtreme patrol (1st November 2011)
    Feb 2011
    Brisvegas
    If you are going to get the tank welded anyway, ask the fabricator to indent the line of the tank where the ring hit it?
  9. The Following 2 Users Say Thank You to Silver For This Useful Post:
    MudRunnerTD (1st November 2011), xtreme patrol (1st November 2011)
  10. #8
    Sep 2010
    Lakes Entrance
    Quote Originally Posted by Finly Owner View Post
    Tim
    I did mention pumping exhaust gas into the tank when talking to the welder he said that after washing the tank out with detergent several times and letting it air for a few days it should be right but i have my doubts it still has a slight petrol smell so im going to tell him to just pump it full of exhaust gas anyway
    Quote Originally Posted by Silver View Post
    Good idea but one of the mounting brackets are in the same spot you can see in the last picture it hit the bracket as well.
    The welder is a patrol owner too and he thinks that some adjustable panhards would solve the problem but im going to get him to weld some angle iron over the edge just in case
    Thanks for the suggestions guys i will see what the welder can do
  11. #9
    Expert chester's Avatar
    Apr 2011
    I had the same problem in my GQ ,adjustable panhard rods is the go like you said.
    I had to cut a section out of my tank due to the upper control arm slicing a hole in it,so don't have the tailshaft drama anymore.
    A GOOD MATE WILL BAIL YOU OUT OF JAIL, A BEST MATE WILL BE SITTING NEXT TO YOU SAYING YEP WE F**KED UP
  12. The Following User Says Thank You to chester For This Useful Post:
  13. #10
    SUCH IS LIFE Maxhead's Avatar
    ACT
    Bugga, you were able to get home on gas then?
    ________________________
    ______ 2017 D-Max _______
