Results 1 to 2 of 2
Thread: 2.8 wast gate not opening
    Advanced aaron's Avatar
    Jul 2011
    rockhampton
    Question 2.8 having some problems ?
    Hi have a 2.8 td have a EGR block and butter fly removed yet it seems that my mec waste gate is staying shut ??? Also has been sooting hard latly with a small puff of white smoak at 100km every now and again witch i know is unburnt diesel had timeing checked all good there and have had spring replaced in injector pump ??? culd it be injector's or boath ? not doing it alot only round 100-120km every now and again ???? any help wuld be grate thank you
    Banned
    Apr 2011
    Greenbank QLD
    25 Post(s)
    Hi Aaron,
    This is a bit out of my field but I was just reading on another forum about a guy who had a similar problem with his 2.8td and it ended up being a loose bolt on the crankshaft balancer.
    Seeing as this is a common fault with the 2.8s I think it is worth checking.
    I hope you get it sorted.
    Cheers Rodney
  3. The Following User Says Thank You to Yendor For This Useful Post:
    aaron (24th October 2011)
