Page 15 of 52 FirstFirst ... 1314151617 ... LastLast
Results 141 to 150 of 517
Thread: Blocking the EGR Valve
  1. #141
    Sep 2011
    A big thanxs to Timbo for the template and dimensions, always a big help to have the game half won for you.
  2. #142
    Advanced aaron's Avatar
    Jul 2011
    rockhampton
    hi i have a 1999 patrol 2.8 td have put a EGR block plate in dose it need a small hole ????? or not ?????
  3. #143
    Expert Chaz's Avatar
    Sep 2010
    Adelaide
    Quote Originally Posted by aaron View Post
    No, no need to drill a hole for the RD28, just remove the butterfly valve pre-cooler.
  4. The Following User Says Thank You to Chaz For This Useful Post:
    aaron (5th October 2011)
  5. #144
    Jul 2011
    rockhampton
    where is that located how do i remove ???
  6. #145
    Hardcore the ferret's Avatar
    Sep 2010
    on the coast W.A.
    Aaron, It's also a good idea to fit a boost gauge and pyro, so you can keep an eye on things mate.
  7. #146
    Sep 2010
    Adelaide
    Sorry mate, I didn't explain it very well. The butterfly valve is fitted "pre-intercooler", or on to the inlet of the intercooler. The system works by closing the butterfly valve in an effort to reduce boost pressure to the inlet manifold when maximum EGR is needed. You'll see this setup on all conventional turbo diesels that use a waste gate turbo, and that also have EGR fitted to them.
  8. #147
    Jul 2011
    rockhampton
    what temp & boost shuld it be running with the EGR blocked ? will it cors damage to my 2.8 ?
  9. #148
    Oct 2011
    Hiya Ferret.
    I am a year late, but did you ever actually punch a few of these out and if so can I get one mailed to me?
    Let me know how many beer vouchers you want!
    Joe
  10. #149
    Sep 2010
    on the coast W.A.
    Plenty of EGR plates Joe, PM sent mate, oh yeah, Cab sav's the go these days lol.
    Cheers, the ferret.
  11. #150
    Advanced albi's Avatar
    Oct 2011
    home of the gods NEWCASTLE
    hi mate i new here and this is my take on this subject
    removing or blocking the EGR is not a performance mod !! it only works at cruise and it lowers the cumbustion chamber temp to reduce NOX "nitrides of oxygen" a very silent killer if it leaks into cab!!
    the sooting is a by product we have to live with ,it is a polution control device and ""ILEAGAL" to remove or modify the same as removing a cat converter$10 grand fine if caught!!
    so if you leave it there it already is a performance mod ! well kind off lol.
    so in a nut shell , if i cut ur arm of ,you can live without it cant you ?? but if it wasnt ,it would be better !!
