Results 1 to 10 of 13
Thread: Question for all LPG / GAS userīs
    Oct 2011
    Frankston North,Victoria
    Hi Guys,
    i just wondering if some of u have a LPG setup (Dual Fuel) in the GQ Petrol (Carbyīs) and have fitted a snorkel to it.
    U guys have any problems with it, like Backfire...missfire...consumption!?!
    Will be really happy for every kind of ideaīs and experiences.
    Will be great if u can post wich kind of gas system is fitted and maybe a photo of the snorkel setup!
    Oliver
    Oct 2011
    No one???
    Com on Guyīs---where the gas driverīs?
    Oliver
    Banned Bigrig's Avatar
    Oct 2010
    South of Brissy, QLD
    I had dual duel mate, but EFI - even then they are prone to stalling, backfiring etc with a snorkel, but I believe the balance pipe usually sorts it (with a 1/8 hole in it near the airbox - don't know why, but stopped the stalling at speed that I experienced).
  4. The Following User Says Thank You to Bigrig For This Useful Post:
    Nordic (14th October 2011)
    Banned
    I have a GQ TB42s mate but no snorkel as yet (its on its way though)
    I run a imco "L" converter into a 300a mixer & it works well for me.
    I get on average 17lts to the 100 on a trip & 20 to 22 around town. It'll creep up a little higher then that out 4x4ing but not much more.
    I am a mechanic who cut he's teeth on this type of system (they are an old system BTW) & I have rebuilt & tweaked this one quite a bit to get it right but the figures speak for themselves.
    I run a 118ltr WC tank in the back which as 100lts useable. last test I got 528ks & still drove into the servo under power (LPG) so im pretty happy.
    I also run a 120ltr long range fuel tank under the drivers side but can't give mileage figures on that as I've never done them, but im tipping theirs 500+ k's in that as well so I should go the distance ....hahahaha
    I've setup 2x snorkels on other patrols running the same gas system as mine & have had no problems with either & I should be able to get pics of one.... I'll see what I can do there & if all goes well I'll post them up for ya.
    Paul
  6. The Following User Says Thank You to patch697 For This Useful Post:
    Oct 2011
    Thats the way aha aha...i like it...thats the way!
    Thanks Paul and BigRig...
    More More....pls
    Oliver
    Banned
    Quote Originally Posted by Bigrig View Post
    The Balance pope equalizes the pressure in the converter coursed by the added air pressure created by a snorkel or similar cold air intake devise. this added pressure interrupts the signal to the converter from the mixer of amos ring which stalls the gas flow.
  9. #7
    Expert NewDan's Avatar
    Oct 2011
    I have a GQ TB42e on gas, dont have a snorkel but its on cards in the near future, only had it for a couple of weeks and only stalled once, it was when I was idling with the aircon on ( It was a bugger to restart, took about 5 full min). Although it does go through rough running patches when it gets the second half of the LPG tank. Also interested to know peoples experiece with snorkels.
  10. #8
    Oct 2011
    Yeah,
    where is the experience? ;-)
  11. #9
    Oct 2010
    Quote Originally Posted by Nordic View Post
    Hi Guys,
    Oliver
    Not sure of my previous gas setup, but the new one is gas research ... I'll take some happy snaps tomorrow arvo an post them up (the air box, balance pipe with the little hole I was mentioning, etc).
  12. #10
    Patrol God taslucas's Avatar
    Aug 2011
    North West Tas
    56 Post(s)
    Hi mate,
    I have a 91 TB42 auto, carby, dual fuel (factory gas) with snorkel. The gas system and carby have been recently rebuilt. I have no backfires or misfires. sometimes it wants to stall when i let off the throttle and coast but only when its cold (up to 10 mins after starting).
    I have heard people talk about running a hose from the air cleaner to minimise this (and your) problem, but not sure where they run the hose to.
    Are you sure they backfire/misfire is due to the snorkel?
    There are a few other threads that talk about the cause of these symptoms.
    Goodluck mate,
    Lucas
    Hello from Under Down Under!
