Results 1 to 8 of 8
Thread: butterfly valve pre-cooler.
    Advanced aaron's Avatar
    Jul 2011
    rockhampton
    hi can any 1 tell me where the butterfly valve pre-cooler is on 2.8 td as have put EGR block plate in ?
    Hardcore the ferret's Avatar
    Sep 2010
    on the coast W.A.
    Four bolts on the inlet to intercooler where the vacuum actuator is.
    Best to unplug the intercooler fan and sensor, remove 4 bolts and take the whole intercooler with mounting frame OFF.
    Then you can get to the 4 bolts, remove them and screw out the two tiny screws in the butterfly shaft, be carefull with the "0" ring, remove butterfly, put it all back together and re install the intercooler.
    DON"T and I mean DON'T, lean or rest on the top radiator tank with your knee or whatever, if you snap the little pipe off, it's another $400.
    Cheers, the ferret.
    EDIT: When you take the rear intercooler hose off, you will see the butterfly inside.
  3. The Following User Says Thank You to the ferret For This Useful Post:
    aaron (5th October 2011)
    Expert Chaz's Avatar
    Sep 2010
    Adelaide
    Quote Originally Posted by the ferret View Post
    Cheers, the ferret.
    Yep, that is the best way to do it.
    If you find doing all that a bit daunting, then just pull the vacuum hose off the actuator and block it.
    I normally just fit a ball bearing into the hose and replace it so that it looks like it's all there and working.
  5. The Following User Says Thank You to Chaz For This Useful Post:
    Jul 2011
    rockhampton
    ok sweet will do is it safe to drive withe out this done atm or shuld i do it asap ?
    atm it seems to spool round 1000 rpm in sted of 1300. is there any thing else i shuld do or know about boy's.
    thank you
    Sep 2010
    Adelaide
    Quote Originally Posted by aaron View Post
    I wouldn't leave it too long before doing it because your ECU will still operate the EGR and butterfly valves for EGR. When this happens, boost will be reduced and this will increase your exhaust temps. This mod should be part and parcel of the EGR blocking proceedure.
    Jul 2011
    rockhampton
    ok bugger ill get cracking on it then might jst put the ballbaring in that pipe for now that way the butter-fly stays open true ?
    Jul 2011
    rockhampton
    do i block the EGR hose or the 1 to the butterfly or boath of them ?
  10. #8
    Sep 2010
    Adelaide
    If you've fitted a blanking plate to the EGR valve, there's no reason to block its hose.
