G'day lads,
could i get some pic of a Cargo Barrier in a GQ... I have done a dual chop and would like to know if i could still get one in..
Pic of where it is mounted would be grate and I could go from there..
Thank guys
G'day lads,
Thank guys
FORCED OFFROAD
Built by NISSAN Powered by HOLDEN Perfected by ME "hulksta"
http://www.youtube.com/watch?v=3GX2M...layer_embedded
http://www.nissanpatrol.com.au/forum...Gq-v8-daul-cab.
You looking for a half or a full?
I thought there was only one type. So In that case the standard full cargo from bottom to top.
FORCED OFFROAD
patch697 (20th September 2011)
I was looking at an adjustable barrier today that has two rods running verticle with suction type cups on the ends. The rods are adjustable from floor to roof so you can easily fit it an remove it. No bolting in. It was just under $200.00 at Autobarn.
Hope this helps
Yeah I've seen them, there like the dog barrier for cars.
Thanks for the reply mate, but not what I'm after. My patrol has no rear window and will be involved In competitions, so if I put on then skids what's In the back stays there and also keeps out thieves as it a canvas rear roofing.
FORCED OFFROAD
I picked up a 2nd hand Milford barrier. Depending on which shop you ring you have to drill holes which I won't do & then you don't. I had a quick muck around with it & i think it bolts into the grab rail holes & pre-existing holes in the floor. I picked up some flat bar today & if it doesn't I'm going to fab up a way to mount it, so not to have to drill any holes.
The conspiracy theorists were right!
