Results 1 to 10 of 19
Thread: Tyre Pressures and off road vehicles
    Some of Andrew St.Pierre White's off-road training. This time, the effect of tyre pressures on off-road performance
    Greetings all powerful and imperious Admin... You spotted the discussions we were having over in the Auto Tranny thread eh...
    First I freely admit that I used to drop my pressures way down when off road and it wasn't until a few years back that I changed on the advice of a Comp driver when I asked him what to run in my newly purchsed Pro Comp Xterrains... his answer blew me away as they were MUCH higher than I thought.
    Currently I run Coopers and I use the pressures recommended by the Manuf which incidentally are close to what I used in the Pro Comps
    Cooper Tyres pressure recommendations (and indeed I have found them to be pretty good for my Cooper Disocverer's are MINIMUM (go higher for loaded truck)
    Gravel - 32 PSI
    Rough Gravel - 26 PSI
    Rocks - 22 PSI
    Mud - 22 PSI
    Sand - 18 PSI
    My truck is very heavy with the gear I carry and I actually run higher by about 2 to 4 PSI except on the Beach Sand around SWWA which is like Custard so I drop to 16 to 18. Get onto the hard packed southern beaches of the Southern Ocean and you can stay higher
    Different people will have different views which is totally cool... I was advised that higher pressures have the advantages of
    1 protecting the side walls... in LT tyres the tyre stands upright and puts the tread between the case and sharp objects
    2 less chance of spinning the tyre on the rim
    3 less chance of crap in the beads
    4 less chance of popping a bead
    5 less chance of internal tyre failure... the ply's are not "working" against each other as the tyre distorts laterally
    BUT... the bottom line is 'The right presure is the one that works for you'. I just used the Manufacturer's recommendations as a starting point and found them to be excellent 'cept for the local sand conditions
    - Yes, you caught me ET.
    - Exactly right, whatever works for you mate, I've also been known to drop mine down ridiculously low and almost ripped off the rims up at Fraser Island and Simpson in certain spots, just depends on what works for you and the situation.
    I love the part in this video where the second guy is demonstrating by lowering the PSI to hug the log and get over and he almost didn't make it. it actually worked 10 times better with a higher PSI..haha.
    He then mentioned he had no idea why it was happening...They should have cut that bit out I think.
    He had to be in 2wd for that to happen. Oops! Is this guy a recognised 4x4 guru? He should sack his video editor.
    No guru that I know, just a 4wd trainer not associated with this site at all.
    Banned
    G/day ET I agree with your advice. I do a lot off road in the sand also & tend to do most if it at between 18 to 25psi I have gone down to 10psi but only over a very short distance but as you already mentioned it really depends on the circumstances.
    Paul
  6. #6
    ilikedonuts_10
    Guest
    Would these change for BFG all terrains? I was talking to a guy who said they didn't have as strong tyre walls so they might be different?
    ta
  7. #7
    Patrol God Finly Owner's Avatar
    Jul 2010
    Waterford West Qld
    As I have said b4, we did simpson desert in HG Holden and did not go real low on pressures and made it all the way through without tyre damage, and only being towed over two or three dunes.
  8. #8
    Apr 2011
    To get highway pressure, I use this rule of thumb (used for years not sure where I came across it).
    Check pressure cold (car full loaded)
    Check pressure after an hour of the driving on the highway. If the PSI is greater than 4 psi the tyre is over inflated, less than 4 psi the tyre is under inflated.
    I wouldn't just deflate/inflate (unless they are excessive) to the same amount as the pressure / temp are intrinsically related. I just ensure that I keep it in mind and adjust it the next time the tyres are cold
    TOOR
  9. #9
    Quote Originally Posted by Ruby View Post
    TOOR
    Other way around isn't it?
    If the pressure changes by more than 4 PSI then the tyre was initially under inflated and is generating to much heat and is in risk of a case failure ?
    Thats why you have to slow down with tyres aired down... to keep the temps down
  10. The Following User Says Thank You to the evil twin For This Useful Post:
    Ruby (3rd April 2011)
  11. #10
    I think ET is right.
    The 4psi rule has been mentioned on here before and although I have never tried it I think it is a good rule of thumb.
    Tony
