Page 3 of 11 FirstFirst 12345 ... LastLast
Results 21 to 30 of 101
Thread: My attempt at installing a LOKKA brand Auto locker
  1. #21
    Patrol God Sir Roofy's Avatar
    TRAFALGAR VIC
    35 Post(s)
    Quote Originally Posted by growlers71gq View Post
    Now for a brain teaser...... whats wrong with the 4th foter?? :-)
    And foter 2 is a grease packed bearing, bit hard to take a foter of the process as i had grease from arsehol3 to breakfast hahahhahaha, Tony question how much grease should i pack into the hub (roughly)
    17mm spanner jamed on the tyerod arm
  2. #22
    Feb 2011
    Shed
    45 Post(s)
    Quote Originally Posted by roofy View Post
    Closeish but not jammed
  3. #23
    Nasty Dog - Moderator Woof's Avatar
    Perth WA
    63 Post(s)
    Not only the 4th photo has a problem but so do all of the others............................................ ..where is the beer?????????
  4. #24
    TRAFALGAR VIC
    35 Post(s)
    breakerbar going wrong way
  5. #25
    Feb 2011
    Shed
    45 Post(s)
    Quote Originally Posted by The Dogman View Post
    CCn dry cans on a Friday night doggy spoil me self night btu the cans still on the bullbar at this stage thats a mutha to carry and a can hahahahah
    Yup I'm a d!ck head ay was tryin to tighten instead of loosen nearly popped a valve hahahahahaha
  6. The Following User Says Thank You to growler2058 For This Useful Post:
    Woof (26th August 2011)
  7. #26
    TRAFALGAR VIC
    35 Post(s)
    not really you just forgot the beer pml
  8. The Following User Says Thank You to Sir Roofy For This Useful Post:
    growler2058 (26th August 2011)
  9. #27
    The main part of the bearing (the bit with the rollers) needs to be packed full of grease, the bearing cone needs a good smear of grease. As for the rest of the hub it doesn't really matter how much or little, I normally just put a light smear of grease in there to stop it rusting and catch any dust that might get in there. Put a light smear on the hub seals as well to lubricate the running surface.
    Nice job so far, your work bench is just like mine.......needs a good tidy up.
    Tony
  10. The Following User Says Thank You to YNOT For This Useful Post:
  11. #28
    Feb 2011
    Shed
    45 Post(s)
    Instructions from 4wd systems
    I'll be using these instructions and the manual fouind on the forum
    Attached Files Attached Files
  12. The Following User Says Thank You to growler2058 For This Useful Post:
    Silver (27th August 2011)
  13. #29
    Feb 2011
    Shed
    45 Post(s)
    OK heres stage 2
    So breaker bar an rubber mallet (my favourite bashin thing), then i ve got the centre out. Ive followed the instructions in the pdf attach above. The shaft had visible wear but under 1.5 thou so no worries im rekon. The photo of the crown wheel bolts and threads and the 12v hammer gun, I rekon they were loktited in were hard as f!@k to get out this unit is sh1t hot a definate favourite. My pin punches werent long enough to knock the shaft lock pin out so used a small phillips head s/driver
  14. The Following 3 Users Say Thank You to growler2058 For This Useful Post:
    AB (28th August 2011), Silver (28th August 2011), Woof (27th August 2011)
  15. #30
    Feb 2011
    Shed
    45 Post(s)
    had a bit of a brain fart and took a bit to read the instructions properly (theyre in effen small print) so took a while to work out how to get the pins and springs in and a couple of these probably werent helping. The act of getting the lokka in is piece of pi55. Following the instructions i greased relevant bits so they hold in position, then with the pins in the slotted groove stepped bit down i lifted into their correct location with a small screw driver then as ya can see in the fpters pushed the springs up n in very easy then just a case of putting back together exactly. Hence why i marked crown wheel and bearing carriers with liquid paper so's could realign, was a bit fiddly due to bulky heavy bloody thing (aligning the bearing carriers that is theyre grooved mountings and must go back exactly the same). Did i say how effen heavy the centre is complete, getting it back in was hard and a smater bloke may use a trolley jack to assist The third ta last foter is making sure u use the pin punch to dent over the shaft locking pin so it cant come out. And the last two are WTF are these bits left over now its all back together hahahahahahhahahahahahaha no longer required. Tomorrow axles back in wheels on WOO EFFEN HOOOOOOOO
  16. The Following 3 Users Say Thank You to growler2058 For This Useful Post:
    AB (28th August 2011), frenzy (29th March 2012), Silver (28th August 2011)
