Results 1 to 10 of 19
Thread: To Turbo or to just Extract??
    Aug 2011
    Thinking of getting a turbo fitted to my TD42. not sure weather its worth the money, more to the point, if i put a set of extractors and a 2 and a half inch exhaust system, will i notice a change in power???
    Banned Bigrig's Avatar
    Oct 2010
    South of Brissy, QLD
    Theres a few threads on here specifically for that topic mate - I'm on tapatalk, so can't cut and paste the link (someone else may be able to), but if you search TD42 and turbo, you should find a fair amount of information.
    Good luck with it mate.
    Hi Mike,
    I just put a second hand GU turbo to my GQ TD42 and after it got professionally tuned I highly recommend it mate!!!
    Below is a link to more info about it...
    http://www.nissanpatrol.com.au/forum...-to-a-N-A-TD42
    Expert GUte's Avatar
    Perth
    The way I see it, a turbo manifold will probably cost the same as extractors and then all the extras you need are a turbo, oil lines and the intake side, you were going to get the exhaust done anyway so its not a whole lot more coin to get it turboed. You should be able to pick up a ht18 for bugger all, they're $795 brand new delivered off ebay.
    Extractors will do stuff all by themselves, these engines need to be force fed
    Edit
    If you are looking for a used turbo, td42ti models are oil cooled only, td42t models were oil and water cooled.
    An oil cooled only turbo will be easier to install
  5. #5
    Expert TuffTD42's Avatar
    Feb 2011
    Central West, NSW
    I would go turbo. CI engines don't react as well as SI engines to extractors because of the higher compression ratio. So back pressure around the port isn't as much as a problem in CI as it is in SI engines. After driving a TD42 with 2.5 exh & extractors & a snorkel I couldn't tell any difference to that of my old N/A stock manifold/exh Patrol.
    I hear all sorts of stories about how adding extractors adds another gear or it nearly go's as-well as my mates turbo'd patrol etc bullsh@t. I think there would be gains. But so minimal it's not noticeable. Now turbo, that you will notice.
    Cheers jono.
    The conspiracy theorists were right!
  6. #6
    Expert makeitfit's Avatar
    Aug 2011
    Aberporth beach, west Wales, UK
    I give in, what's an extractor?
    Y60 Patrol 4.2 d SWB in puke green
    2" body lift, 2" pedders suspension lift, 35" Simex muds on excel 16" alloys, needs a turbo :/
  7. #7
    Quote Originally Posted by makeitfit View Post
    Headers or tuned length exhaust manifolds. Much more efficient at scavenging exhaust gases from the cylinders than the standard cast iron exhaust manifold.
    Tony
  8. The Following User Says Thank You to YNOT For This Useful Post:
    Patrol Tico (4th September 2011)
    Aug 2011
    Ah gotchya, a bit like this then
    http://www.ebay.co.uk/itm/3005821693...84.m1423.l2649
    What sort of money are they down under?
  10. #9
    Sort of, extractors for naturally aspirated motors look more like the one below which cost $235 (Aust$).
    The link you've posted is for a very sexy set of tuned length pipes for a turbo engine.
    Tony
  11. #10
    Aug 2011
    I've been using that turbo manifold pic for my mate to make one up for me. I'm going down the turbo route soon
