Page 1 of 6 123 ... LastLast
Results 1 to 10 of 54
Thread: Rear Recovery Point in Tow Hitch
    Advanced satyx's Avatar
    Aug 2011
    Rockhampton, Central Queensland
    I have a question regarding the recovery points like the one below used in tow hitches. I was ready to buy one untill my old man pointed something out. The point is held in the hitch by the pin, so why not use the pin to hold the stap, ie feed the loop into the hitch and lock it inplace with the pin. Ive seen him do this before so it has made me wonder what the benifits of the recovery point is?
    2005 GU 3.0L ST
    Cooper tyres, Alloy B'Bar, Safari Snorkel, 3" Exhaust, Rhino Racks, Dual Batt, NADS
    and a very big wishlist in the glove box...
    Aug 2011
    2005 GU 3.0L ST
    Patrol God Bob's Avatar
    Oct 2010
    Pakenham
    47 Post(s)
    Quote Originally Posted by satyx View Post
    I always use that method when snatching someone.
    Banned Bigrig's Avatar
    Oct 2010
    South of Brissy, QLD
    Using the pin is sort of ok except for two reasons:
    1. The strap around the pin is smaller in width on the pin than a recovery hitch, hence placing greater strain on the pin across a smaller surface area
    2. Further to point 1, in doing so, you run the very real prospect of bending the pin in the tow receiver - ever tried to get one out that's bent?? Be bloody hard mate.
    The recovery hitch is solid through the centre where the pin goes and places surface area strain across the pin equally from side to side and having the snatch rope attached to the bow shackle allows slight angled movement of the snatch from side to side (if not a dead straight recovery) without placing too much strain directly on the pin and tow receiver.
    Add to that trying to attach a snatch strap to a receiver pin whilst you waist deep in water and/or mud - no fun!! Far easier to a recovery hitch.
    I'm sure there's a more scientific reason, however that's my philosophy and I personally never use just the pin - $50 for a recovery hitch is money well spent.
  5. The Following 9 Users Say Thank You to Bigrig For This Useful Post:
    big_fletch (10th August 2011), Bob (10th August 2011), jman69 (29th April 2012), patch697 (10th August 2011), PT Paul (29th August 2011), satyx (10th August 2011), Sir Roofy (10th August 2011), snicko (10th August 2011), the ferret (10th August 2011)
    Aug 2011
    Quote Originally Posted by Bigrig View Post
    See thats why this fourm is gold. I knew there had to be a good reason for them to be available, I had thought of the side to side movement of the strap, but the old man just said "every snatch should be straight on". The contact surface of the pin and strap v pin and block makes sense. Ill slip that one if he coments about it. lol. Thanks BigRig
    2005 GU 3.0L ST
    Oct 2010
    Pleasure mate - slip this one in also - when Haymen Reece invented his tow assembly and receiver, he did it with "towing" in mind and subsequently the pin is meant to have load spread on it and generally speaking, those loads (towing) are substantially less force than an attached snatch strap recovery. Spreading the load by using appropriate equipment might seem an overkill, however if it means being able to use something that was designed for another use (towing), then what is $50 in the scheme of things??
    A bent pin (or worse, a complete snap or separation) versus $50 ...
  8. #7
    Tassie
    Also ever tried hooking a winch hook over the pin in the reciever not going to happen, just alot more versatile i reckon.
  9. The Following 2 Users Say Thank You to Chappa For This Useful Post:
    Bob (10th August 2011), Silver (10th August 2011)
  10. #8
    Hardcore 04OFF's Avatar
    Brisbane,QLD
    12 Post(s)
    I just removed my tow "ball", and found a 4.7T rated bow shackle pin fits in the remaining tounge hole perfect ($15 Total)
    And you only need keep the "towball" (and a spanner) in the car should you need to convert it back to a standard towball (instead of a complete tounge and ball)
    The problem often overlooked, is with regard for the car you are recovering (or thats recovering you) , you may have a strong tow point, but if their "weaker" tow point breaks, its ALL coming YOUR way !
    I keep a towball spanner and a spare 4.7T Bow shackle in my car, this way, i can easily convert anyones towbar into a safe recovery point in the same manner, should the situation arise.
  11. #9
    Patrol God Sir Roofy's Avatar
    TRAFALGAR VIC
    35 Post(s)
    All points of recovery are good here
    but for my money i like the hitch reciever most
    its solid and very little wear points on the bow shackle
    as well
  12. #10
    Patrol Freak BillsGU's Avatar
    Jul 2010
    Thurgoona
    7 Post(s)
    One point you are missing is that the HR bar is not rated for snatching. It is generally accepted in the 4WD world that a properly fitted HR bar (with high tensile rated bolts) is suitable for recovery - but you will never get it on paper from Hayman Reece.
    The fact is that every time you introduce another link in the recovery chain you are introducing another place where something can go wrong. These adaptors (the ones I have seen) are well made, but they are welded (which can let go) and you are then also introducing a shackle (is it rated or a cheapie from China / India?).
    When using this adaptor the force of the recovery is not spread over the entire length of the pin - it is focused on the holes in the HR bar and the holes in the adaptor (much like a shearing action happening on the pin).
    I have never used an adaptor - I always feed the loop of the strap into the HR hole and feed the pin through it.
    I have done dozens (maybe hundreds?!) of snatches in the course of the Off Road Training and Recovery courses that I have conducted and I have never seen a pin bend or break. I have however seen a couple of shackles distort to the point where they are difficult to undo.
    Lastly - the adaptor is another heavy lump of metal floating around in the back of the car.
    Just my two bobs worth.
