Page 26 of 220 FirstFirst ... 2425262728 ... LastLast
Results 251 to 260 of 2192
Thread: AB's new GQ is finally here
  1. #251
    Have your boost and pyro gauges arrived yet? If/when they do start mounting them and run the wires for the back lighting so all we have to do is connect the thermocouple (pyro) and hose (boost) to get them working. It will save time doing it this way as we need the gauges for tuning.
    I now have the tools for checking TD42 injector pump timing so we may be able to check that as well and adjust if necessary.
    Have you got the hoses and clamps to connect the alloy inlet pieces between the turbo and inlet manifold?
    Tony
  2. #252
    Quote Originally Posted by YNOT View Post
    Tony
    Yes, I picked that up today.
    Not yet, should be in tomorrow at the latest....My exhaust just turned up today...Can't wait to fit that puppy!!!
    Do I Just run them to the ciggy lighter plug, I think Paul mentioned this the other day?
    Great stuff, thanks again Tony!
    All of the lines will be done by Wednesday. I will pick them up and also pick up some new manifold gaskets and dump pipe gasket.
    This weekend I am going to connect every single component up to Rosscos engine and make sure it all fits and figure out if I am missing anything.
    Will report back with photos, etc soon!!!
    Getting excited!!!
  3. #253
    Exhaust has arrived....Super excited about this one...I can't wait to hear it roar!
    The Iphones take pretty crappy pictures...lol
  4. #254
    Perth WA
    63 Post(s)
    Looks like things are coming together for you mate, well done
  5. #255
    Just ordered the manifold gaskets and dump pipe gaskets from Garry at Nizzbits.
    Great bloke to deal with and very quick. I want to get the proper manifold gaskets and make sure this turbo is done right!
    Getting the sump plug put in on Saturday and then I will fit up the whole turbo, lines, etc onto Rosscos TD42 engine in his shed this Saturday and make sure I have everything.
    Apart from the below, I think I am good to go!!!!!
    • Tap 3/8 BSP to sump
    • block pcv holes
    • air filter
    • Missing clip for air filter housing
  6. The Following User Says Thank You to AB For This Useful Post:
    Woof (27th July 2011)
  7. #256
    Well folks I am completely done now and have all the parts for the turbo!
    Trevor from Pirtek on Canterbury Road in Bayswater is the man to speak to for getting your oil and water lines, etc. Very helpful, actually cares about what you are doing and charged me bugger all for all the work he has done...
    Patrolapart in Lilydale are helping me out to by putting the plug into the sump tomorrow morning for the oil drain at an insane mates rates price!
    Big write up and piccies coming your way soon...Give me a couple of weeks though...LMAO
  8. The Following 4 Users Say Thank You to AB For This Useful Post:
    belzi82 (29th July 2011), Clunk (30th July 2011), patch697 (29th July 2011), Woof (30th July 2011)
  9. #257
    WA Wheatbelt
    23 Post(s)
    Nice one, AB.
    Pics please.
    Rossco
  10. #258
    Had a great day of Patrols today!
    Took Rosscos new TD42 back to get some studs taken out that had snapped in port 6 of the manifold (block) which was nice of them to do for free.
    Oil drain has been plugged into the sump, no leaks and they did a fantastic job!
    Here is the comparison of a standard dump pipe off a GU turbo and my 3" straight through dump pipe...Big difference!
    Hooked up the turbo with all the lines today onto Rosscos TD42 and was one happy chappy that all the lines fit perfectly!!!!
  11. The Following 2 Users Say Thank You to AB For This Useful Post:
    Clunk (12th August 2011), Woof (30th July 2011)
  12. #259
    Feb 2011
    Shed
    45 Post(s)
    Mate cant wait ta hear that turbo sing
  13. #260
    Almost there!!!!!!!!!!!
    Just put the airfilter housing in, connected it up to the 4" snorkel, connected breather pipe, etc...
    Fitting the 3" filter outlet to the 4" snorkel was absolute carnage!!!
    Lots of chopping, grinding, shaving and precise measuring to reduce down from 4" to 3" with about a 65mm gap to play with and to also tighten up clamps.
    I just have to fit the pyro and exhaust and then I'm done!!
    Crossing all fingers tonight when I fit the exhaust tomorrow....Praying that the hangers fit on the exhaust!
  14. The Following User Says Thank You to AB For This Useful Post:
    Woof (13th August 2011)
