Page 1 of 3 123 LastLast
Results 1 to 10 of 21
Thread: Loosening a stuck nut...
    Jul 2011
    Hey guys,
    I've tried everything for this nut short of voodoo magic.. and the ****** thing won't budge no matter what I do.
    I've had a large-ish breaker bar with about 3 large-ise blokes leaning on it, I've tried soaking it in WD-40 and then the same 3-bloke treatment, I went and rented an electric rattle gun which, the gentleman at the store assured me would get anything undone.. As a last resort I've tried heating it with a blow torch, 3-bloke breaker again, as well as hitting it with the rattle gun while heated.
    So, the nut in question is hard to explain. It's the nut that holds in the tail shaft flange, for the front tail shaft on a 4.2d GQ patrol. It's a big 30mm nut - its in where, once you take the front tailshaft off the gearbox, the big nut that sits under there.
    (I need to take it off, because I've just dropped a 4.2d motor into a 2.8t chasis - I've modified the engine mount etc, but the ***** diff's and tailshafts are different. Price of parts wise changing the flange was the cheapest way out of it)
    So, any tips or experience from anyone who's ever tried to loosen this particular nut, or a similarly tight nut, would be very much appreciated ! Thanks.
    Patrol God Finly Owner's Avatar
    Jul 2010
    Waterford West Qld
    not sure, do they have a roll pin through them, that needs tapping out with a pin punch first?
    Tim
    Are you sure you're turning it the right way? I've always been able to get them undone with a 600mm breaker bar and a similar size tool to hold the flange (diff out of car).
    No roll pins Tim.
    Tony
  4. The Following User Says Thank You to YNOT For This Useful Post:
    Finly Owner (14th July 2011)
    Patrol Freak BillsGU's Avatar
    Jul 2010
    Thurgoona
    7 Post(s)
    You could use a tool called a nut splitter. It has a jaw that fits onto the nut with a cutting edge that splits the nut in half when you tighten it. Its the last resort but ALWAYS works.
    Try this site
    http://www.toolworks.com.au/hand-too...splitters.html
    Expert GUte's Avatar
    Perth
    Is your engine running?
    I took mine off yesterday, started the engine and let the clutch out in 4L in 1st, worth a shot. If you do it in reverse, it will tighten I believe
    Banned
    Quote Originally Posted by GUte View Post
    Forgive me for being naive but I fail to understand how this would work when the front shaft needs to be removed in order to access the nut being referred to above?
  8. #7
    Banned
    I was wondering how you going about anchoring the Diff yoke while your attempting to undo this nut?
    If the yoke is not properly secured, ie: (held firmly in its place while attempting to undo the retainers nut) & your only relying on the Diff internals to stop the yoke from moving then an impact gun will have little effect & nor would much else in fact as the fall effects of the impact itself will be absorbed by the Diff internals, ie: Its loading up the Diff center & the other moving parts which means its not isolating the full force of the impact to the retainer nut itself.
    Loading up the Diffs internal components in this way ie: (using a breaker bar & or impact gun without securing the the yoke when attempting to remove the yoke retainer nut) could cause them to become damaged & you may already be in full knowledge of this info but I thought it would be worth a mention all the same.
    All the best
    Paul
  9. #8
    334 Post(s)
    Mate take note of what Paul and Tony have written.
    I note that you only have 1 post so not even sure you are still about??
    I have to say that my last resort for undoing stuff is one of these EzyWrenches from KCI
    http://www.kcimports.com.au/item.php?i=31#gallery
    Mate i have never found a nut that i could not undo with that little gem. I have cracked an Alternator Pulley while resting the Alternator in my other hand without holding the pulley...CRACK!!! and your done.
    Big Winner for me.
  10. The Following User Says Thank You to MudRunnerTD For This Useful Post:
  11. #9
    Feb 2011
    Shed
    45 Post(s)
    Big Winner for me.
    X2 these things are the ducks guts
  12. #10
    Nasty Dog - Moderator Woof's Avatar
    Perth WA
    63 Post(s)
    Welcome mate, it is always good to post up an introduction before asking questions, just gets everyone on side at the start.
