Have read with interest the posts on factory alloy wheel issues with Patrols.
Recent purchase of a 2011 ST GU 3L TD has highlighted this issue. The vehicle as supplied from the dealer was fitted with 'nut indicators', ranging from nil to six per wheel (go figure that one) - total of twelve supplied. On checking nut torques these ranged from 110 Nm to 185 Nm (OM says 133 Nm/ 98 ftlb - assume for both alloy and steel as no advice is given on this in OM).
No wonder problems exist with the alloy wheels - steel wheels are a little more forgiving of 'over-tightening'. Crushing of alloy wheels around the tapered stud holes is also an issue from what I read. Have reset nut torques to 133 Nm and will check to see if changes occur.
I would be interested to hear if other members have been able to extract 'reliable' info from Nissan on this issue.
Keep the wheels where they should be - on the vehicle!
Eagle 202
