Page 6 of 8 FirstFirst ... 45678 LastLast
Results 51 to 60 of 78
Thread: My GU wagon
  1. #51
    Advanced moddedgu's Avatar
    Sep 2010
    Ipswich, QLD
    Ready for integrated Intercooler manifold
    All bolted up
    Might even have a go at getting it in troll tomorrow!!
    Patrol GU Wagon
    TD42, Garrett BB high mount,
    Air Lockers, Crawl gears,
    suspension lift and other fruit.
  2. The Following User Says Thank You to moddedgu For This Useful Post:
    GUtsy ute (2nd July 2011)
  3. #52
    Feb 2011
    Shed
    45 Post(s)
    Sh1 t hot mate go ya hardest!!!
  4. The Following User Says Thank You to growler2058 For This Useful Post:
    moddedgu (2nd July 2011)
  5. #53
    Sep 2010
    Ipswich, QLD
    Thanks guys, It is a big job but hopefully it turns out good!!
    Patrol GU Wagon
  6. #54
    Sep 2010
    Ipswich, QLD
    Ok, we put in another big day today, finished off the couple of little things that needed to be done before fitting the engine.
    Patrol GU Wagon
  7. The Following User Says Thank You to moddedgu For This Useful Post:
    GUtsy ute (3rd July 2011)
  8. #55
    Simpson Desert GUtsy ute's Avatar
    Apr 2011
    Forestdale Brisbane
    Mate you deserve that drink, what an awesome build up and great pics to go with it.
    What a beast it will be!!
    No doubt you will savour that first start up moment, then enjoy what you have spent so much
    time and effort in creating!!
    I hope it's as good as you are expecting it to be, enjoy!
    The pics are the ducks nuts too!!
  9. The Following User Says Thank You to GUtsy ute For This Useful Post:
    moddedgu (3rd July 2011)
  10. #56
    Sep 2010
    Ipswich, QLD
    Thank you GUtsy ute, It has been a long hard haul, and a fair whack of cash mind you. But I built this myself so I new what went into it. I'm one of these that just hates getting told one thing and finding out another!
    I will keep the pics coming as I continue to finish the engine part off and then get onto doing the Intercooler fit up, installing the heat exchanger etc.
    Cheers David
    Patrol GU Wagon
  11. #57
    Well done mate, you definately earned that drink. Is Matt sending you a complete exhaust manifold or just an adaptor?
    Tony
  12. #58
    Sep 2010
    Ipswich, QLD
    Quote Originally Posted by YNOT View Post
    Tony
    Tony, No just the adaptor! He didn't like the one I had on my exhaust manifold!! Lol nor did I for that fact!
    David
    Patrol GU Wagon
  13. #59
    Sep 2010
    Ipswich, QLD
    Update, Have had a few hiccups last 2 days. first one totally a stuff up from me; I was cutting off some brackets ready for heat exchanger and grinder bit in and pulled it into Air Condition condenser! :-( So got another coming tomorrow. That gas stinks btw.
    The other was trying to remove the old Turbo manifold adaptor and replace it with one of Matt McInnes lil sweetie. Had massive problems removing stripped out headed button top Unbrako screws.
    The old one removal
    All off and in the bin
    So tomorrow I hope to finish off the engine side and start on the Heat exchanger mountings if they arrive early enough.
    Patrol GU Wagon
  14. #60
    Sep 2010
    Ipswich, QLD
    Today consisted of a bit of driving around getting a few bits and pieces. You don't realise how much extra stuff you need until you start doing it.
    Didn't quite get to where I wanted to but manged to get this completed.
    Fitted Starter Motor and connected wiring.
    Run and connected the wiring to all the mating connections, alternator, Air cond, etc
    fitted new Glow Plugs.
    Removed old Airbox (ZD30 Styled lid and base) make way for a donaldson 7" beauty.
    Fitted all new Belts, Alt, Power steer, Air con.
    Install Matt McInnes Adaptor flange. Very neat piece of craftsmanship.
    Fitting the gasket then the cam lock studs
    Flange fitted with camlock pins in place
    Patrol GU Wagon
