Results 1 to 3 of 3
Thread: GU Door Decals missing or off from factory?
    Nov 2024
    Perth
    Hi Members,
    Hoping to get an answer regarding door decals missing?
    I'm in the process of looking for another GU Patrol to buy, but some advertised have the side door decal and some do not.
    My Question is have they been removed or can you order a decal delete from factory?
    I know some ppl remove them because they don't like the look and some ppl remove them for theft deterrent reasons. IE owning a 4,2 model.
    I personally like to have the door decal on.
    Cheers for any input
    176 Post(s)
    Maybe removed because the doors have been repainted? Lower section gets stone chipped when used on gravel roads.
  3. The Following User Says Thank You to Cuppa For This Useful Post:
    Donnie1 (19th November 2024)
    Assuming you are looking at the 3.0Lt the lack of a door decal generally means the Direct Injection ZD30 and the Common Rail has a big decal. You want the Common Rail for sure.
    If you are looking at the TD42T then its a bit of hit and miss. My GUIV TD42T did not have a decal on the doors from factory. There are plenty of non-factory, 3.0lt Converted to TD42Ts running the 4.2 Decal.
