Results 1 to 10 of 12
Thread: MAF sensor help
    Nov 2012
    Eastern Suburbs, Victoria
    Question MAF sensor help
    hi guys
    after reading through a few threads decided to give the maf sensor a clean.
    went and bought the sensor cleaner and a t20 torx bit and went to open it up however the bit doesn't fit?
    I'm not very good with what different bits are called but can someone please tell me what i need to use to take these out to open the sensor? Its like a T20 fitting but has a small piece of metal protruding from the centre of the bolt?
    hope this makes sense...
    thanks
    Mark
    2007 ST 3L Turbo Diesel Manual Patrol - Stock as a rock ...
    Patrol God Sir Roofy's Avatar
    TRAFALGAR VIC
    35 Post(s)
    think its the the same tool with a hole in the centre anti theft
    is what you need
    X 2 Roofy normally see those on allen keys
    where are you located
    Nov 2012
    argh nice cause it would be so easy to steal a maf sensor under a locked bonnet -_- lol
    Im in Ferntree Gully Ill head down to bunnings after work tomorrow and pick up a tool for it.
    Thanks for the help guys appreciate it.
    mark
    Not sure Bunnings would have one ,so good luck I'll read here if you got one or not
    Aug 2010
    adelaide
    i went to repco last week and got a set of them $20.00 ahd the guy took them out of packet to make sure they fit
    OH LEATHER IS NICE
    Nov 2012
    just went to bunnings and they have a full range of them in a couple of different brands.
    bought the t20 size in the security style and fits perfect.
    will open it up and finish the job once i get home tonight.
    thanks for all your help guys.
    Mark
    Good to hear, keep that tool in your centre console , along with maf spray
    markp90 (7th December 2012)
  11. #9
    Expert grimace's Avatar
    Apr 2011
    central coast N.S.W
    don't forget, the sensor is very delicate so don't touch it with your fingers just hold the plastic part of it as they are easily broken!
    2008 GU 2" LIFT, GME UHF BLACK KING WHEELS, SAFARI SNORKEL, LIGHTFORCE 240' KAYMAR DUAL WHEEL CARRIER STEINBAUER POWER, beaudesert 2 3/4 system, runva 11,000 comp winch.....
  12. The Following User Says Thank You to grimace For This Useful Post:
  13. #10
    Nov 2012
    yep thanks for the advice, I had a good read through the other post on here about how to clean them.
    thanks
    mark
