Didn't know you were building a TD42 mate.
Also radiator, a/c pump, alternator, pwr steering, pretty much everything that attaches to the engine. Engine mount brackets need to be cut off and new ones relocated and welded on. Bell housing, clutch, flywheel, air box, new wiring loom. Im sure there's more as I am only just starting with mine. This will be a long term project for me as my ZD30 is still going strong plus I have a 5spd box I am building up as well so they can go in together.
So as I get further along I will be scratching a few members brains for info.
@ Thomas that's why I brought an auto as the nerve to my leg would pinch at any time and engage the clutch
very dangerous, but had my last 4x4 for over 400k so over a manual 4x4 big time, as for motor not sure what I would put in
Turbo diesel not ideal as an off roaded,need to be on boost all the time,, maybe the Infinity motor// who knows what will
be available when the time comes. But updating to a CR makes sense as a lot of my accessories will fit
He does make some sense in that if you don't need the economy (for touring and distance), something like an LS1, bang for buck can be more responsive. I guess why many comp guys run V8's and turbo'd TB's......
Not saying a TD isn't better in the majority of applications though.
Turbo diesel is not ideal for off road work , perfect for towing.
what do you think the top comp trucks have its not a turbo diesel that's for sure.
trying to keep them on boost all the time.
My last 4x4 will go up hills @ 1000RMP tell me your TD will do that
A good upgrade would be a more efficient turbo and intercooler, you could also get the die grinder out and match port the manifolds and flange on the turbine housing
Talking joe blow yes crawler gears will help heaps as would any highly modified rig
but getting away from OP .
A td42 will maintain its ability to pull from from around idle turbo or not.
Thomas,
I used to have the Dtronic Chip, and mine was great.... only available second hand now.
I would look at Chip-It, Diesel Smart or Steinbeuer .... there was a chip comparison done somewhere which lists the benefits and modes of operstion for each of the major chips
Mic
I want the distance and torque of a diesel with the capabilities of towing and going off road but as many of us have the ZD's they aren't good on torque
Gturbo do a bolt on upgrade turbo for Di and CRD.
http://gturbo.com.au/
Yeah just in the very early stages mate. Its a long term build....
Sorry ET, I just read my OP. Was a bit drunk last night, it was an eight hour trip I did with the trailer. From Melbourne to Merimbula. South coast of NSW.
Hi TW,
I would echo what some others have already said and from my own experience I would suggest a good chip, a 3" exhaust, an EGT monitor and a Dawes valve is all you will need to get a reliable, better performing vehicle that you can enjoy for years. There are heaps of extra mods that can be done but - how deep is your (or my) wallet? This is plenty and relatively inexpensive (for the results anyway).
Chip-It are an excellent product - possibly the least expensive of all the chips and a good company to deal with. You get the USB with all the tune-ups on it so you can bung it on the lappy and adjust as you wish and for whatever application - mine has 17 different tunes from factory to full comp - I run it on a 4 for around home and put it to a 7 or 8 when hooking up the camper and heading off - lift it up to an 11 if towing and hit strong headwinds or mountains - only takes about 3 minutes to set up the lappy and do the adjustments. Much improved performance and better economy at the same time - cant get better than that!
Plus I can leave it on and working when I get services done and that is at Nissan so no dramas there either.
They are about $1100 to $1300 which is far better than almost all others.
Manta make a great 3" exhaust system for the 3.0 - mine is turbo-back as I got rid of the cat, so quicker response and low-down torque is a heap better - probably about $1150 fitted.
The EGT gauge and Dawes valve you can fit at home and they will be a big help in keeping an eye in all things that make us nervous - if you want to get someone else to do the work then the EGT can range from $250 to $500 supplied and fitted, the Dawes Valve should cost under $200 supplied and fitted.
Hope this helps (and no, I am not affiliated with any of the products, they just work and I am happy with them).
Good luck Thomas, and have fun in the Patrol no matter what.
to get the best from your chip it should be done in conjunction with the exhaust.
Maybe I might lift it first then and save more afterwards
put everything on before fitting your springs , winch, dual batteries extra fuel and storage boxes all adds up to weight,
which will need to be taken into account when selecting the right set up for you.
You could do what big fletch did and fit a 2" flexi coils with 4" over shocks.
only heard good things about the flexi coils
