All good, Timbar came round so hd a look at his, low mount just bolts onto the front of the bar using those 4 bolt holes.
Ordered the kits for the highmount rebuild.
With the help of Dazz aka mr winch man he has convinced me to get some added goodies so this will be one nifty little winch once done!!!
Sorted out the recovery points and wired the satphone dock to battery myself after I specifically told the auto elec to do this but he wired to the hazards and blew the pcb...
New km2
High mount rebuild install and fairlead, rope and controller
Rear quarter cut and front guard chop
Front mud flaps
Rear bar
Upgrade turbo and pump, 3" elbow to inlet manifold
Need rear slide windows
Rossco selling me his arb compressor when he gets his air locker
New airbox
Indicators on new bar
New water bottle
Mesh on roof rack
New flares
Door hinges
Put a half decent stereo and speaker system in...lol
Run mandrel bends on aux tank main filler... Winnie, you need to do this too after simmo experience.
got a bit of work ahead of you mate.
Bracing kit for highmount turned up...
Very nice. :)
I'm contemplating putting a scoop on and even possibly throwing a few washers on the back of the bonnet hinge to help out.
Taking the thermo out and a giant ic in front has only "slightly" changed water temps. Nothing to be overly concerned about but still a concern for me.
I know I know, I need to get a proper gauge but I did notice towing the camper on the weekend the needle got to half way, even whisker over on those long hills to gisborne which is still ok in operating temps but the usual paranoid AB sets it in. Never had that pre ic towing.
Summer concerns me...
Will a scoop and raising the rear bonnet help?
Any other ideas?
Car is fine without towing, just want to make sure I can have it sorted for the next touring adventure towing the camper up north, etc...
Any suggestions appreciated!!!
Just thinking the cheap stuff first, are all the rubbers around the engine bay in place properly? Like the ones around the radiator and on the sides inbetween the body and chassis, they make a difference to the airflow into the engine bay also.
I wouldn't stress too much at this stage, just keep monitoring it and see how it goes as the weather gets a little hotter then assess it then. You could upgrade radiator if needed. Others might have more insight, but not sure if a scoop would do too much to coolant temp. . . .
So basically you're putting a dollar value on your pride... haha
Forgot to mention that I now have full confidence in my ic installation!!!
Got caught in a medium sized watery dog poo hole for a considerable amount of time and it all held together with no contamination into the engine thank god!!!
Safe to say I was nervous as this was a true test on my installation but happy days!
Hate to rain on your parade AB, but the intercooler is pressurized, so nothing would get in even if it wasn't sealed very well..
Everything for the highmount has now turned up bar the 6hp motor.
Can't wait to get this running!!!
Thanks to Darren directing me to Amazon their prices are cheap for the rebuild kits and motor.
Did it need a new motor or are you putting a bigger one on it? What is the motor worth?
After seeing Gary's high mount on the weekend I'd be tempted to buy one if I stumbled on a cheap one
Do you know what thermostat you are running?
Motor turned up, everything is ready to go!
Would like to get rope on this winch when money permits rather then cable too.
Where's the best place to source this?
Rossco got his front air locker which of course cane with the compressor that he already has so snuck in and snagged a deal with old mate.
Finally got a compressor so don't need to bug you lot to air up...lol
Slowly chipping away at this list!!!
I'm running out of room under the hood and cannot see AB immediate spot for this compressor without relocating things.
I guess the next sensible thing would be under the seat.
Not that I want to do this but has anyone mounted theirs in the rear?
I'm guessing the longer wires will result in less air flow but just curious if anyone has done this and feedback?
