Installation of Steel Mate 386M Central Locking Kit.
Thanks Jeff.....just brought one for 1992 GQ and have yet to install but your explanation has taken the bite out of any muckup i may do.........when i brought mine i asked the guy at Jaycar if the flashers would work and he said he had a conversation with another person in regard to that question and they said the brown wire hooked into the turn signal/flasher wire should do the trick, so i will give that ago as well.......so hopefully that helps you also. cheers
