Where can I get a couple of keyless remotes for my series 2 without having to sacrifice one of the family jewels
Mister Minute,will cost you a left nut, close to $150 last time I asked a few years ago![]()
Try Nizzbits.
2004 GU111 4.2 TURBO WAGON, 2" OME SUSPENSION, 33" MTZ's, 3" BEAUDESERT EXHAUST, ARB ROOF RACK, ARB AWNING, BLACK WIDOW DRAW SYSTEM & CARGO BARRIER, DUAL BATTERIES, 12,000lb WINCH, GME UHF, LIGHT FORCE XGT SPOTTIES, BERRIMA DIESEL TUNE.
Parri Nissan, Townsville. Spares. Ask for Jon Schulz. I purchased one from Ebay via Jon. He has done his homework. As mine was a series 1 ST was out of luck as only series 1 TI had this option. Not sure about later sreies.
Cost was $145 shipped.
He may be able to help you.
Cheers!
My local key and battery kiosk fitted new fobs with the original existing electronics for my GU IV--about $50. No programming needed.
This only works if you have the old keys. Happy to assist getting it done.
If this helps, send me a PM
I got fed up with my factory remote central locking not working as it should. And worse, with the pathetic range it was getting. So I just pulled out the stock unit and wired in a replacement one from Jaycar. Saved me plenty of cash and now can get a good 50m of range. Haven't had an issue since.
http://www.jaycar.com.au/productView.asp?ID=LR8839
Cheers,
Matt
Ironman 4x4
mudski (30th July 2014)
Same here. I bought a whole new remote and controller from JB Hi-Fi. Was 90bux or there abouts. took about ten minutes to wire in too. I made a DIY guide for other to use...
http://www.nissanpatrol.com.au/forum...der-20-minutes
