Had enough of the zd30.. decided to go ls..
Sent from my SM-N915G using Tapatalk
http://www.nissanpatrol.com.au/forum...015/10/216.jpg
Out she comes..
http://www.nissanpatrol.com.au/forum...015/10/217.jpg
Rear sump..
http://www.nissanpatrol.com.au/forum...015/10/218.jpg
Au thermo fans..
http://www.nissanpatrol.com.au/forum...015/10/219.jpg
Clucth n flywheel..
http://www.nissanpatrol.com.au/forum...015/10/220.jpg
Fittings and line to make up power steering...
Good boat anchors those things mate ...
http://www.nissanpatrol.com.au/forum...015/10/221.jpg
Bellhousing... hoses n other shite..
http://www.nissanpatrol.com.au/forum...015/10/222.jpg
Flexy getn drilled out to bolt to new marks flywheel... the slot need to be drilled out to 13mm...
http://www.nissanpatrol.com.au/forum...015/10/223.jpg
Strippn out looms to be away so i can get spliced to ls loom for a true plug and play wiring loom...
http://www.nissanpatrol.com.au/forum...015/10/224.jpg
Engine chassis post drilled out to suit the new rubber mounts...
http://www.nissanpatrol.com.au/forum...015/10/225.jpg
Rubber mounts fixed in the engine bay...
http://www.nissanpatrol.com.au/forum...015/10/226.jpg
Heat shield for the starter needs to be trimmed dwn to suit drivers side engine mount... you could probly take the whole shield off but i decided to trim mine dwn as the headers come pretty close to the starter...
http://www.nissanpatrol.com.au/forum...015/10/227.jpg
Side shot of the aircon relocation bracketry...
http://www.nissanpatrol.com.au/forum...015/10/228.jpg
Frnt shot of the aircon relocation setup... marks do a good bit of gear...
http://www.nissanpatrol.com.au/forum...015/10/229.jpg
http://www.nissanpatrol.com.au/forum...015/10/230.jpg
Aircon and alternatir relocation brackets all done.. tidy n functional...
Looking good mullet. There is nothing better than the sound and torque of a V8. Keep the pics and updates coming. Great job.
OMG,,,,,,,,,what have you done with all the ZD 30 gear, My last 4x4 was a 75s troopy with a cast iron 350 chev, mild work done,, pretty loud
and combined with twin lockers idled up anything, It did feature on one 4wd TV episode, scared a lot of 4x4s too
After it settles down are you fitting long range tanks lol nah LS1 is your thing from what I know of you
it was only a matter of time eh.
Whats the history on the donor engine??
http://www.nissanpatrol.com.au/forum...015/10/231.jpg
Old bellhousing removed... such a gay job unbolting bellhousing bolts frm back of engine.. two 800mm extensions and a couply unis did the trick tho...
http://www.nissanpatrol.com.au/forum...015/10/232.jpg
Front case removed.. cleaned up surfaces with carb cleaner then new gasket sealer for a good seal between gearbox face and new bellhousing face...
http://www.nissanpatrol.com.au/forum...015/10/233.jpg
http://www.nissanpatrol.com.au/forum...015/10/234.jpg
Pic shows relocation for power steering resavoir...
http://www.nissanpatrol.com.au/forum...015/10/235.jpg
Pic of engine mounts... nice and beefy..
http://www.nissanpatrol.com.au/forum...015/10/236.jpg
Welsh plug that needs to be punched out for new dip stick...
http://www.nissanpatrol.com.au/forum...015/10/237.jpg
Removing plug and refitting sump..
So what's the conversion going to set you back??
Iv budgeted 10k... should be pretty close but id say 12-13k max.. you could obviously save money and do things a bit cheaper but i just wanted to do it once and do it right the first time.. the ol saying.. poor man pays twice.. haha
You know you could have done a Cummings 6BT turbo for that... 😆 lol
It's a good looking build. Marks do a great kit hey. They have really thought it threw well..
I should have 300hp at the treads with a tune.. if anything brakes i can get spare parts pretty much anywhere in aus... 15l per hundred.. plenty of torque and plenty of reliable power upgrades.... if needs be dwn the track.. like heads and cam... no issue with water crossing etc... just look at all the comp trucks these days... engineer has been realy helpful and told me how to word my application so i dont have to get any emissions test done... hopefully get a bit more time to hook into it and finish it.. but pretty happy with my day and a halfs progress...
http://www.nissanpatrol.com.au/forum...015/10/245.jpg
Pic of starter n heatshield cut dwn to clear the drivers side engine mount...
Just need to reroute fuel and brake lines to run ontop of the chassis instead of dwn the side.. install heat shield and then reroute diff breather lines on the other side then engine bay is pretty much done... and ready for its new heart..
http://www.nissanpatrol.com.au/forum...015/10/248.jpg
Pedal mount asessbly.. for fly by wire pedal..
http://www.nissanpatrol.com.au/forum...015/10/249.jpg
New/bigger slave and braided line that comes wiv the marks bellhousing kit...
http://www.nissanpatrol.com.au/forum...015/10/250.jpg
Fuel system...
http://www.nissanpatrol.com.au/forum...015/10/251.jpg
Corvette style reulator/filter and walbro intank pump..
http://www.nissanpatrol.com.au/forum...015/10/252.jpg
Most people just use a 4.5 sender but il be modifying my zd30 sender to suit... the picture above is of the bulkhead fitting.. which will keep my fuel tnk sealed and alows me to run a single power feed wire to and frm my walbro pump instead of just drilling a hole and patchn up with silicone like most average joe blows do..
Again what happened to the mighty ZD30 ?
Nothing happened... it still lives just not in my patrol any more.. lol
Ok why not the bigger LS2? $$$$$'s
You get 15/100 tell him he's dreaming LOL
15-18l is the norm with the right tune... my l98 pulls 11 on the highway... but those figers can change depending on hw u drive.. what ratios u have.. and size of tyres etc...
Should see low teens on the highway. 15/100 would be pretty standard for normal driving. I get 12-13 out of my l98 normal driving, 10 on the highway. Add a few extra hundy kilo and that will use a bit more fuel.
Looks like it's a fairly simple conversion. Have been thinking about dropping an ls in my patrol.
Cnt wait to get it finishd.. just busy with wrk and other stuff and all my free time is spent with the kids and cleaning up aftr them... hopefully a early knock this friday and fingers crossd drop her in next weeknd... 2 weeks wait on my loom which is bit of a bummer...
Was gona go killer but ended up going with sideshow performance as i wnt a true plug n play loom and he knws his stuff..
Obviously alot cheaper for a stand alone harness but mine will be modded to suit my patrol n needs.. like plugs for my thermos... vats and tune... new wires to alternator and battery... extended loom to house computer in 2nd glove box.. all i need to do is plug it all back up.. hookup the positive terminal and negative terminal and hit the key... all dash will work as per normal including the engine light etc...
