Dawes valve, egr block for a dummy with a crd
I know I know.... This topic has been done to death , I have read and read all about it.... Just about every topic about Dawes valve and egr blocking gets answers from almost all engine types and it confuses the hell out of me.
So a simple question for those with the knowledge on crd,s
If I install a Dawes valve and block the egr( both of which I have sitting there ready to do) do I need a boost control needle(or alike) or is it still controlled by the ecu ( which is my preference) as I understand once egr is blocked the ecu doesn't control the boost or is that on the di, and not the crd?
I know about the need for a hole in the egr( have scan gauge )but might tempt fate without it, do I need gasket or some sort of sealant for both sides of the egr plate if not which side do I place the original gasket( engine side or exhaust side?)
And if anyone has any photos of the Dawes valve done a crd it would be much appreciated.
For the record.. The boost I am currently getting on my scan gauge is 16psi tops but see the needle on my pod guage quickly spike to 18 ish for milliseconds so not sure which is correct and once I block the egr I expect things to rise.
So basically I am after dedicated info for the crd,s as this is really starting to confuse me.
Thanks Scotty
