Ah right gotcha.
This might have just happened......
http://www.nissanpatrol.com.au/forum...019/03/128.jpg
@mudski here it is under the front seat.
http://www.nissanpatrol.com.au/forum...019/03/129.jpg
I love the Ford seats, they are comfy as and have plenty of support.
On my list for sure Dazman!
So i had to strip the drivers door to retrieve the rear mount for the door mirror. Once in i couldnt find what i expected to be fairly small. I spent a couple ofhours cleaning and organising my GQ bits and pieces trying to find it along with eveything else i need to finish.
After getting my arm in the door and taking pics looking for it i finally lo cfc ated this thing jammed in the side impact bar. I had felt it a few times and though it was part of the door assembly. Bloody thing is huge!!
http://www.nissanpatrol.com.au/forum...019/03/135.jpg
Finished mounting the bull bar and side rails.
http://www.nissanpatrol.com.au/forum...019/03/136.jpg
http://www.nissanpatrol.com.au/forum...019/03/137.jpg
Spent a couple of hours refitting the grill again. Needed to remove and cut 6 or 7 times. So much now in the way.
http://www.nissanpatrol.com.au/forum...019/03/138.jpg
Grille buttons for the winch in but not wired yet
Emptied it of all the Shit......
http://www.nissanpatrol.com.au/forum...019/03/139.jpg
http://www.nissanpatrol.com.au/forum...019/03/140.jpg
http://www.nissanpatrol.com.au/forum...019/03/141.jpg
http://www.nissanpatrol.com.au/forum...019/03/142.jpg
http://www.nissanpatrol.com.au/forum...019/03/143.jpg
Its soooooooo bloody Close now gents!!!!!!!
http://www.nissanpatrol.com.au/forum...019/03/144.jpg
Looking good Dazz, time for its maiden voyage to Mansfield :)
Getting very bloody close mate, ready for winter!
Top stuff Daz, exciting times ahead mate!
Don’t forget to affix some new plates soon too [emoji106][emoji106]
http://www.nissanpatrol.com.au/forum...019/03/145.jpg
Nice Darren. Looking foward to seeing this beast done. Just in time for Licola.
http://www.nissanpatrol.com.au/forum...019/03/146.jpg
Or
http://www.nissanpatrol.com.au/forum...019/03/147.jpg
How about
Attachment 78172
‘BILT4B’ for sure mate, good work [emoji106][emoji106]
On the road this Friday @MudRunnerTD
Big thanks to @Lights for coming over tonight. Big night. 24v winch lives. Getting exciting now. Bloody close. Thanks Paul. Winner mate.
I spent some time on it this weekend. So close gents.
So i tested the roof lights and they did not work. I noted also the rear light not working and the air free spool not working. Damn it. Traced the trigger back off the high beams and was all good.
Out with the passenger seat and flipped the console again damn it.
Traced the circuit for the roof light and had 12v at the B pillar. Had 12v outside the roof! Damn! Dead light bar??? Surely not.!!!! No. The dickhead that fitted the Anderson plug reversed the polarity..... easy fix but had to wreck the silicon.
Fixed.
Took the inner guard and inside door trim off the back door and while jiggling the wire on the relay the bloody light came on. Cut and replaced a couple of connectors and good to go.
Tested the and air freespool and everything works
The rear airlocker didnt work last trip out so had a look at it. Had air at the diff so removed the fitting from the housing and its blocked. I will bit a new fitting kit and might avoid stripping the rear diff which is a bloody winner.
Nearly there gents.
Getting bloody close now.
Many little jobs finished. Fitted the grille. Parker lights. Filled the winch with oil.
Trying to adjust the bonnet and snapped a bolt damn it so the bonney had to cone off!
Took the opportunity to run the washers back in and fit some LED Lighting.
http://www.nissanpatrol.com.au/forum...019/03/305.jpg
http://www.nissanpatrol.com.au/forum...019/03/306.jpg
http://www.nissanpatrol.com.au/forum...019/03/307.jpg
http://www.nissanpatrol.com.au/forum...019/03/308.jpg
http://www.nissanpatrol.com.au/forum...019/03/309.jpg
http://www.nissanpatrol.com.au/forum...019/03/310.jpg
Winch grill switched in and labeled
http://www.nissanpatrol.com.au/forum...019/03/311.jpg
http://www.nissanpatrol.com.au/forum...019/03/312.jpg
http://www.nissanpatrol.com.au/forum...019/03/313.jpg
http://www.nissanpatrol.com.au/forum...019/03/314.jpg
http://www.nissanpatrol.com.au/forum...019/03/315.jpg
Re fitted the airline to the rear winch with a new fitting and the airlocker works again!!!! Yippee!!!
http://www.nissanpatrol.com.au/forum...019/03/316.jpg
http://www.nissanpatrol.com.au/forum...019/03/317.jpg
Just for interest this is the part i needed. Before buying online i did a price check at ARB......... $12 in stock. Identical.
http://www.nissanpatrol.com.au/forum...019/03/318.jpg
Tidied up the winch 24v wiring and added some extra insulation
http://www.nissanpatrol.com.au/forum...019/03/319.jpg
http://www.nissanpatrol.com.au/forum...019/03/320.jpg
http://www.nissanpatrol.com.au/forum...019/03/321.jpg
Fitted 2 Air Vessels for extra storage.
http://www.nissanpatrol.com.au/forum...019/03/322.jpg
http://www.nissanpatrol.com.au/forum...019/03/323.jpg
http://www.nissanpatrol.com.au/forum...019/03/324.jpg
http://www.nissanpatrol.com.au/forum...019/03/325.jpg
Swapped to a pin for the winch dildo
http://www.nissanpatrol.com.au/forum...019/03/326.jpg
http://www.nissanpatrol.com.au/forum...019/03/327.jpg
And modded my winch hook to be a quick release for my new 12mm rope
http://www.nissanpatrol.com.au/forum...019/03/328.jpg
http://www.nissanpatrol.com.au/forum...019/03/329.jpg
http://www.nissanpatrol.com.au/forum...019/03/330.jpg
Then made 2 fid in 12mm to use to work with my 12mm rope. Going to make a couple of soft shackles and splice in my loops
http://www.nissanpatrol.com.au/forum...019/03/331.jpg
http://www.nissanpatrol.com.au/forum...019/03/332.jpg
http://www.nissanpatrol.com.au/forum...019/03/333.jpg
12mm FTW!!!
Looks good Darren, What make and specs are on the air compressor?
In case you were wondering. A 12mm soft shackle is Massive!!
http://www.nissanpatrol.com.au/forum...019/03/335.jpg
http://www.nissanpatrol.com.au/forum...019/03/336.jpg
http://www.nissanpatrol.com.au/forum...019/03/337.jpg
http://www.nissanpatrol.com.au/forum...019/03/338.jpg
That used 100inches of 12mm rope. Made one with 60inches and could not complete it was too small.
Thanks for that. I am looking to upgrade my old ARB diff lock compressor - had it since 1997, so its served its time, still pumps OK. If I cant sort out the endless air unit when I tear the front of the engine down I think I will go a big one - will have to look at the ARB twin also.
I bought a couple of 11mm units a while ago, not small either. I will say however that I am still sitting on the fence regards using them instead of a metal shackle for winch pulls - impact or energy situations like snatch stuff, yes, won't hesitate, but need some more assurance I think - the 'knot' bit is what has me cautious.
Your nut looks larger than mine, but thats hardly surprising is it!!!!! I don't doubt the mechanical strength, its just my engineering mind getting stuck with shackles as we use them every day and no soft shackles are rated for lifts - again, just a mind block. Right bit of gear for the job in some circumstances I guess.
Jeez its coming along really nice now Darren. Whats that big post thingo you go hanging off the front of the bar for?
Self pleasure device, aka dildo.
Hey @MudRunnerTD, who would have thought driving around with a big black dildo on your bullbar would attract so much attention and comment - boy is society so unreadable these days. I think it looks GRAND!!
Wankers.
So Mark the winch dildo is a polyurethane winch dildo. Designed to hook a 24v himount hook too when spooling in. The 24v himount spools fast and can be a little dangerous when spooling in so hook on and get hands out of the way. it flexes and takes the load of the winch when spooling in.
Flexible Winch Recovery Mount:
AKA Winch Dildo
AKA Donkey Stick
AKA Jousting Pole
Full steam ahead Dazman[emoji106]
Very considerate Polyurethane choice too, some poor sods have Latex hypersensitivity!
Ok Brain is fried. One of the last things for me to do is refit the rear tail light assemblies. As you will note in the pics through this thread i have neglected them terribly and left them hanging exposed for the better part of 4 years. Idiot.
One was smashed so i bought a pair of new lights. They come plug and plat but not a plug that exists on my car so had to splice.
Problem is the previous splice was hideous ans at end of life and a mess. Add to that sun faded colours. And im colour blind....
6 hours yesterday and another 8 hours today making completely new looms for both sides. Back to basics. Typical bloody Nissan though there is bulk loom in there that is not being used and a couple of extra wires cost me hours of trolling through the factory manual electrical section looking at bloody wiring diagrams looking for a colour that didnt even exist. You Shit me Nissan.
http://www.nissanpatrol.com.au/forum...2019/04/83.jpg
Looms removed.
http://www.nissanpatrol.com.au/forum...2019/04/84.jpg
New looms made long enough to comfortably remove the full lights without restriction.
http://www.nissanpatrol.com.au/forum...2019/04/85.jpg
http://www.nissanpatrol.com.au/forum...2019/04/86.jpg
http://www.nissanpatrol.com.au/forum...2019/04/87.jpg
http://www.nissanpatrol.com.au/forum...2019/04/88.jpg
Nearly done gents. Front flares to go.
