If your engine is a TD42T, I think your standard pump already has the 11mm plunger..[/QUOTE]
It's also "limited edition plus".
no computer, no egr system as std.
wider shorter radiator also, if that helps any.
Yes it's td42t, but it wasn't intercooled ex-factory. "Is now".
Month & year model of engine 3/2002.
If this is the case we are getting somewhere now ,more brains coming to the party!.
I hadn't come accross that info before.
Any way I can tell by looking at the pump ?.
A case of all non turbo are 10mm GQ, excluding turbo safari imports ?.
and GU with ht18 are 11 mm std ex-factory?.
