One Coleman dual burner and one three burner. The dual is 30 years old the other 2 y/o, both work very well.
Butane for us , canisters are easy to pack and can be purchased everywhere. Work well on cold damp mornings if you rotate 2 canisters or poor some of the warm water on the canister. Used one in minus 13 in the high country with no issues as the air was dry.
I also have a Lido Junior & rate it highly. Two burners & a griller. It is a low pressure stove requiring a regulator on the gas bottle. Much quieter to use & better than previous high pressure/direct connection stoves we’ve had to cook on. Also a little larger, better space for a couple of pots/pans. Not sure why but it will actually boil water quicker than those stoves used without a regulator. If considering a Lido Junior be ware that there are 2 or 3 different models. I chose to get the one with the flame out safety cut out, even though this wasn’t legally required for my set up. It added about $100 to the cost! I did make a couple of wind shields for it though that we attach with neodymium magnets as the low pressure flame is a bit easier for the wind to blow out.
I got a Webber Baby Q via flybys not used at all..
When I bought my caravan it came with one of these in a slide out set up:
http://www.marinebarbecues.com.au/sizzler-pro
Great BBQ.
I did some searching and contacted the distributes and up graded it to this:
http://www.marinebarbecues.com.au/sizzler-deluxe
Ok caravan has a 3 burner stove in it so I am cheating.
Now I don't need the BabyQ. Still in its box unused.
Don't need it at home as I have 2 of these (and one other from Barbecues Galore, got a 5 burner + spit and side burner from them at half price as I made too much noise re their shit products very cheap) :
http://www.beefeaterbbq.com/signatur...93761_1001221/
OK greedy 3 BBQs at home. 2 on operation all 7 days a week.
So who wants to get a Webber BabyQ cheap?
I have no use for mine.
Re the comment the BabyQ true. Send me a PM if interested.
Not looking at full price anyway.
Unused all I have done is open box to check its all there.
I have 3 BBQs at home, Colman 3 burner stove and a 3 burner stove in van . I don't need this Webber Baby Q.
Mine is ‘semi permanently’ mounted I suppose. It is mounted inside the pod, but on drawer slides. To get around any issues with clearances from combustible materials & regulations about permanent gas connections I have a gas bayonet fitting outside close to the stove, & pull out the stove on the slides & plug into the gas to use. Takes a few seconds. Removal from the vehicle altogether to use elsewhere is just as quick & I have a longer hose for this purpose.
The gas connection is at the left hand rear.
Mounting was easy, just a matter of drilling some holes in the base/bottom of the griller section. If attaching to a solid flat surface small ‘L’ brackets would work just as well.
