Rusty, my vehicle is a 94. My fuel pump control unit is situated in the bottom of d/s kick panel. The timer for running the fuel pump whilst the oil pressure rises is defective on mine, due to moisture ingress (it is only a problem if I've drained the carby. ) If your pump is not running, and the fuses are not blown, it may just be the control unit playing up due to moisture or vibration damage, etc.
The fuel cut out solenoid is situated on the carby, ( some one please correct me if I'm wrong). The second stage of the carby was sticking at any position and at random times, and it caused the engine to be an absolute dog. I fixed that by using wet 'n' dry on the butterfly and the carby bore to free it up. The auto choke was playing up so I replaced it with a manual one. As for fuel economy, I got the auto advance diaphragm on the distributor reconditioned.(through Bursons in Warnambool). I used a converted bicycle pump to check it (gently) and found the diaphragm had a small hole in it. After it was fixed, That made my economy to around 15 .64 lt/ 100k at 90 -95 ks an hour( if I calculated it correctly. I'm no mathematician)
