Results 1 to 8 of 8
Thread: crd 150a alternator upgrade
    Nov 2019
    Perth
    5 Post(s)
    I recently had the pulley come off my original alternator, dropping the belt and losing all things important (like aircon & water pump). Not to worry, being only a few kms from home after a trip to Bunnings to buy steel for some solar mounting on my shed, I nursed it home with coolant temp sender reporting 118c due to the lack of coolant flow.
    I ordered the OEX 150a upgrade unit from Patrolapart, waited about 3 days, then put it on. Interestingly, the OBD2 port is reporting 14.6-14.7v while my Victron battery sense is reporting 14.35-14.45v at the battery.
    I haven't tried any huge loads, I'm just happy the car works again. I didn't bother with the included upgrade cable as it didn't look any fatter than the original, nonetheless one could simply piggyback it over the original cable if desired.
    2008 CRD Auto Wagon
  2. The Following User Says Thank You to pollenface For This Useful Post:
    Touses (26th October 2025)
    Reported electrical outputs for a range of things on cars all vary depending on the quality of the devices and the unknown dampening within the circuits. Specifically we find the temp gauge sitting at mid position, always have, then install an aux gage and the water temp is sitting at 95 deg - not much room to 110C where its going to start boiling, yet the time the factory gauge takes to get to the 'red' seems forever. On the Madigan Trip that wasn't, the temp gauge was sitting mid stream and the aftermarket gauge at 100C - To be honest I trust the after market gauge , as long as its a quality brand. Even then the calibration can be off quite a bit. I have volt gauges, pod gauges, and then two different brand hand held multi meter, and they all read differently. The challenge then is to temper the expectation and simply resolve if the numbers are on average, about where they should be sitting and then ignore the 'hundredths of a volt difference'. My lithium bank is supposed to have a float voltage at 100% full of 13.5V - it floats at 13.35, does not matter what I do, all 4 batteries are the same. After a lot of time spent testing and going back and forth to the supplier, I decided to set the 100% on the gauge to 13.35V and happy days - means nothing. If the performance of the battery charge circuit changes its going to be reflected in the capacity value. Specific to your issue, this may then reversing my point, but I would be inclined to believe the OBD port than the Charge controller as there is no advantage for Nissan to over report battery voltage. I think you could look at volt drop as the culprit here as DC is a nightmare especially at low voltages. Run a parallel cable to increase the conductor size from alternator to the controllr and see if that helps. I have found cable size on my intercooler pumps to be absolutely critical to get them to pump at the rated speed and shift the water. o.5 volt drop on the circuit and the output can drop from 30LPM to 15LPM and then the temps go up.
  4. The Following User Says Thank You to PeeBee For This Useful Post:
    typo368 (24th November 2025)
    Nov 2019
    Perth
    5 Post(s)
    I have two aftermarket temp gauges personally, scan gauge and engine guard with probes on the hot side of the motor and cold side of the thermostat housing.
    What are you using to charge your lithium battery? Float is not completely necessary for LFP. I have 38.4v lithium battery in the back which receives 41.2v from a boost converter while cranking batteries are above 14.2v.
    Quote Originally Posted by pollenface View Post
    I use 2 x 100amp Renogy Chargers that are specifically set up to allow parallel charging up to 200amp - its a particular model, not crazy expensive and I wanted to have the back up of at least 100amp charge if one died. Regards my float volts, during charge with a 30 amp charger I can get the boost voltage at circa 14.7 then it equalises to 13.50V, switch off the charger, disconnect the earth and within 4 hrs its floating at 13.35. Have tried individual batteries on chargers up to 120amps, same result, float is 13.35V All good for me, spectacular performance compared to AGM which were 3 times the weight and half the usable capacity. The bank size is 400amp, being 4 x 100, bought this specific model of battery for the drawdown peak to allow running of a 10KW 12/240 inverter to run a mig welder - works faultlessly. My alternator is 300amp rated 100% duty cycle but most I have seen it pump out is 190amps. I had to upgrade cables etc and also have the cables punning a selective parallel route, so primary cables to the 100amp charge controllers and then a second direct cable runs to the batterie via a marine selector switch, so I can punch in more if required as the batteries can accept up to 250amps if required, nominal charge rated at 120amps. AS usual cables galore, all fuse isolated, very busy, but all works with reliability.
    Maxhead (26th October 2025)
  8. #5
    Nov 2019
    Perth
    5 Post(s)
    Sounds like a pretty serious system, I can only imagine
    2008 CRD Auto Wagon
  9. #6
    My greatest limitation, is my electrical systems installed follow a 'form follows function', which does not deliver the degree of electrical finesse that more electrically inclined others do. As a Mech engineer, my electrical stuff is messy but functional. I am gradually improving and reducing the amount of smoke that comes out of the cable at times, and the reliability is getting a lot better.
  10. #7
    Nov 2019
    Perth
    5 Post(s)
    I assure you, as a machine operator my electrical work doesn't deserve photos
    2008 CRD Auto Wagon
  11. The Following User Says Thank You to pollenface For This Useful Post:
    PeeBee (30th October 2025)
  12. #8
    Nov 2019
    Perth
    5 Post(s)
    Since making this thread, I have learned that the factory alternator has an "overrunning pulley" which is a one way clutch to allow the alternator to briefly continue spinning under it's own inertia without shocking the belt during engine deceleration, the pulley should be replaced periodically, 60-130k. Before mine came off it was making a horrible squeaking metal-on-metal sound and not making any volts, I assume my alternator clutch failed and torque was not being applied to the shaft, I'm taking a stab in the dark here but this irregular torque transference might have been how the bolt un-wound itself.
    2008 CRD Auto Wagon
  13. The Following 2 Users Say Thank You to pollenface For This Useful Post:
    jack (9th November 2025), Touses (9th November 2025)
