Results 1 to 10 of 18
Thread: 15V to 14.8v AGm battery - Too high?
    I just noticed my alternator is starting to put out 15v on start up and after 10 or so mins driving it would drop back to 14.8.
    Yellow top Optima AGM, pretty new batteries.
    Is that too high or is my alternator on its way out?
    Might time for a new one and keep this as a spare for the Simpson anyway.
  2. The Following User Says Thank You to AB For This Useful Post:
    Stropp (18th May 2024)
    I can't answer your question mate but have you checked multiple meters to make sure it's not a misread?
    MudRunnerTD (19th May 2024)
    Yeah definitely mate, I too was questioning my gauges and used two different multis and all three were same.
    .......... TPC's Avatar
    63 Post(s)
    I am not an expert but I believe an AGM cherge voltage up to 15v is good.
  7. The Following User Says Thank You to TPC For This Useful Post:
    AB (18th May 2024)
  8. #5
    63 Post(s)
    Darren probably knows more
  9. #6
    Yeah I’ve read a lot of things on the internet with AGM and it’s such a mix bags of lollies with advice.
    I understand AGM are ok with that charge but it’s only just come on so why I guess is my question.
  10. #7
    Hmmm. Sounds High. A quick google tells me what i already though and that it may be a faulty Voltage regulator, if this is the case it is probably a very simple fix and any Auto Elec could sort that out quickly.
    I did read though it could be a faulty Earth or Neg point. disconnect the battery and disconnect the earth off the Alternator and clean and reconnect and see if that fixes it.
    Here is a quick vid to show removing the voltage regulator
    This is also a very good vid mate. Watch this from the start but also the 8:50 minute mark he speaks about the Voltage Regulator.
    I would not be buying a new Alternator just yet.
  11. The Following 4 Users Say Thank You to MudRunnerTD For This Useful Post:
    AB (19th May 2024), Cremulator (19th May 2024), jay see (19th May 2024), Stropp (19th May 2024)
  12. #8
    Thanks mate, it does sound high but looking the Optima’s website says it’s in range but, at highest point that’s for sure.
  13. The Following 2 Users Say Thank You to AB For This Useful Post:
    PeeBee (19th May 2024), Touses (19th May 2024)
  14. #9
    Interesting they also mention up to 15.6v for a rapid charge.
  15. #10
    It's definitely something you need to get sorted out before the big trip though mate!
  16. The Following 2 Users Say Thank You to Winnie For This Useful Post:
    AB (19th May 2024), MudRunnerTD (20th May 2024)
