Page 1051 of 1056 FirstFirst ... 515519511001104110491050105110521053 ... LastLast
Results 10,501 to 10,510 of 10559
  1. #10501
    109 Post(s)
    Mocked up with black tape, another Wacky MB concept
    Not sure if I love it or hate it yet
    Keen for your honest helpful thoughts prior to welding Team NP.com.au?
    Certainly will keep I believe our pesky local Hills bugs from ram feeding into the airbox, open passenger side window for a Navi would be a lot more bearable too I imagine
    The 30 degree downwards, slightly twisted final bend theory is for parked up outside/overnight camping torrential rains protection.
    Have had previous plastic family GU wagon truckster ram head snorkels fill airboxes overnight and believe poor @Rossco ‘s GQ once did the same nearly hydro-locking his beast on morning startup
    EDIT: Besides looking a little kooky, not powder coated yet Could the extra nearly say 800mm of 4” pipe potentially hinder its air intake? I’m only chasing 150rwkw again
    I’d say no bro. That 30 degree turndown lowers the intake height and if you get water coming over your window height you might be in big trouble.
    Extend it up vertically at least 2 metres to be safe I reckon.
  2. The Following 3 Users Say Thank You to Plasnart For This Useful Post:
    BrazilianY60 (9th May 2024), MB (10th May 2024), Stropp (9th May 2024)
    Apr 2021
    Brazil
    That way he will be able to not just cross rivers but also to cross deep lakes.
  5. The Following User Says Thank You to BrazilianY60 For This Useful Post:
    MB (10th May 2024)
  6. #10503
    465 Post(s)
    I would for sure.
    I struggle on freeways, the Simmo trip will not be fun for me @ 110kmh
    What does yours do at 100kph?
    MB (10th May 2024)
  8. #10504
    465 Post(s)
    I think if he's got water up that high he's in the poo regardless.
    I have a nice looking 6inch chrome air ram here at work he could fit aswell.
    MB (10th May 2024)
  10. #10505
    475 Post(s)
    Cheers Legend’s, you’re all as wacky as I am
    Struggling to locate my old school metal G welding clamps, spoiled myself on the way home and bought some long wanted C Visey grips:
    I’m far from a steel fabricator but this wacky method of mocking up pipe work with tape then tack welding through small tape cut holes N/S/E/W might actually work
  11. The Following 4 Users Say Thank You to MB For This Useful Post:
    Cremulator (10th May 2024), MudRunnerTD (11th May 2024), PeeBee (10th May 2024), Stropp (12th May 2024)
  12. #10506
    196 Post(s)
    Looking good Mark. I had my staino 4" powder coated, came up really good if you want the black look
  13. The Following 2 Users Say Thank You to PeeBee For This Useful Post:
    MB (10th May 2024), Rossco (10th May 2024)
  14. #10507
    194 Post(s)
    All good. I found a s/h box from a 2008 low 100thou on the clock box. George will be doing the r & r for me. Now I'm thinking do I get the Mark 10% overdrive reduction gear now, since I have saved over 2K. This would bring my revs at 100kph from 2450 to 2205rpm.
    Hmmm.
    Yeah do it, have the taller 5th in mine running 4.6s with 35s and 43% reduction gears and very happy with the overall gearing in the old girl. .
    Sent from my SM-S711B using Tapatalk
  15. The Following 5 Users Say Thank You to Rossco For This Useful Post:
    BrazilianY60 (13th May 2024), MB (10th May 2024), mudski (13th May 2024), PeeBee (10th May 2024), Stropp (12th May 2024)
  16. #10508
    196 Post(s)
    Started and completed a pivot bracket for the Codan HF. Allows transport position at 30 deg tilt so it does not get clobbered from trees and branches, then undo 3 bolts and stand it upright with the antenna sections. Required a complicated 40mm RHS frame built and 6mm plate to anchor it to the POD frame and all clamped up with a greased turn plate, happy with the results, just needs the 3 tapped holes at 30 deg to complete.IMG_1913.jpgIMG_1915.jpgIMG_1911.jpg
    Loving the strip lights I got from a forum vendor, Ledlightcompany.com.au. They are so bright and draw nothing, has the added feature of white and yellow, white only or yellow only. Highly recommend them. Talk to Paul, great guy.
  17. The Following 5 Users Say Thank You to PeeBee For This Useful Post:
    BrazilianY60 (13th May 2024), MB (10th May 2024), Plasnart (10th May 2024), Rossco (11th May 2024), Touses (12th May 2024)
  18. #10509
    Not my patrol, not even a Nissan.
    Helped my son install a 2" lift in his Colorado today. Was good spinning spanners, talking shit and having a couple old beverages with him..
  19. The Following 9 Users Say Thank You to jay see For This Useful Post:
    BrazilianY60 (13th May 2024), MB (13th May 2024), mudski (13th May 2024), pearcey (12th May 2024), PeeBee (11th May 2024), Plasnart (11th May 2024), Rossco (11th May 2024), Stropp (12th May 2024), Touses (12th May 2024)
  20. #10510
    196 Post(s)
    Bit more progress, chest infection, again, holding me back, but baby steps get the job done. Finished the pivot mount for the big antenna, then trial fitted the new TRED boxes, ordered another 65L unit, plenty of flexibility, have the rear seat frame platform mod in reserve as well.
    Tred cases option 3.jpgTred cases option 2.jpgTred cases Option 1.jpgcodan pivot assy 1.jpg
  21. The Following 6 Users Say Thank You to PeeBee For This Useful Post:
    10G (13th May 2024), BrazilianY60 (13th May 2024), Cremulator (12th May 2024), MB (13th May 2024), Rossco (25th May 2024), Stropp (13th May 2024)
